Circuit Breaker
Circuit Breaker
Circuit Breaker
Description
An Arc fault circuit breaker is an automatically operated electrical switch designed to protect an electrical circuit from damage caused by excess current, typically resulting from an overload or short circuit.
Block Diagram
Products
Category Name 1 Microcontroller
Product URL 1 Arm® Cortex®-M0+|Kinetis® KV1x Motor Control MCUs | NXP
Product Description 1 The Kinetis® KV1x MCU has dual 16-bit analog-to-digital controllers (ADCs) sampling at up to 1.2 mega samples per second (MS/s) in 12-bit mode, it also has 12-bit DAC and 2 x ACPMs (analog comparators)— over-current and over-voltage fault detection, reduced BOM costs.
Category Name 1 Secure Authenticator IC
Product URL 1 A1006 | Secure Authenticator IC: Embedded Security Platform | NXP
The A1006 Secure Authenticator IC is manufactured in a high-density submicron technology. It is a secure tamper-resistant authentication IC, which offers a strong
a cryptographic solution intended to be used by device manufacturers to prove the authenticity of their genuine products.
Category Name 1 NTAG i2c Interface
Product URL 1 NTAG I2C | NXP
Product Description 1 A 32-bit password protected interface, designed to be the perfect enabler for NFC in home-automation and consumer applications. The NT3H2111 NFC tag is the fastest, least expensive way to add tap-and-go connectivity to just about any electronic device.
Category Name 1 Transceiver
Product URL 1 SA636 | NXP
Product Description 1 The SA636 is a low-voltage high-performance monolithic FM IF system with high-speed RSSI incorporating a mixer/oscillator, two limiting intermediate frequency amplifiers, quadrature detector, logarithmic Received Signal Strength Indicator (RSSI), voltage regulator, wideband data output and fast RSSI op-amps
Category Name 1 SMPS Controller
Product URL 1 TEA172x | NXP
Product Description 1 These highly integrated devices enable low no-load power consumption below 10 mW, reduce component count for cost-effective application design, and provide advanced control modes that deliver exceptional efficiency.
Related Documentation
Document URL Title
https://www.nxp.com/docs/en/application-note/AN11060.pdf
5 W to 11 W Power Supply/USB charger
https://www.nxp.com/docs/en/application-note/AN11276.zip
NTAG® Antenna Design Guide
NXP Semiconductors :: Secure Connections for a Smarter World  NTAG® Originality Signature Validation
Training
Training URL
Power Regulation/Market Trend and Overview of NXP AC/DC Power Solutions
NFC Demos - Information, Source codes, Schematics
NTAG I2C Plus interface to Kinetis Freedom boards
Related Demos from Communities
Related Demos from Communities URL
Secure Authentication
%3CLINGO-SUB%20id%3D%22lingo-sub-1109000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%B5%E3%83%BC%E3%82%AD%E3%83%83%E3%83%88%E3%83%BB%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FCircuit-Breaker%2Fta-p%2F1109000%23toc-hId-380753094%22%20target%3D%22_blank%22%3E%E5%BD%A2%E5%AE%B9%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FCircuit-Breaker%2Fta-p%2F1109000%23toc-hId--1426701369%22%20target%3D%22_blank%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FCircuit-Breaker%2Fta-p%2F1109000%23toc-hId-1060811464%22%20target%3D%22_blank%22%3E%E8%A3%BD%E5%93%81%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FCircuit-Breaker%2Fta-p%2F1109000%23toc-hId--746642999%22%20target%3D%22_blank%22%3E%E9%96%A2%E9%80%A3%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FCircuit-Breaker%2Fta-p%2F1109000%23toc-hId-1740869834%22%20target%3D%22_blank%22%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FCircuit-Breaker%2Fta-p%2F1109000%23toc-hId--66584629%22%20target%3D%22_blank%22%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%8B%E3%82%89%E3%81%AE%E9%96%A2%E9%80%A3%E3%83%87%E3%83%A2%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%0A%3CH1%20id%3D%22toc-hId-380753094%22%20id%3D%22toc-hId-1304214580%22%3E%E5%BD%A2%E5%AE%B9%3C%2FH1%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E3%82%A2%E3%83%BC%E3%82%AF%E9%9A%9C%E5%AE%B3%E3%82%B5%E3%83%BC%E3%82%AD%E3%83%83%E3%83%88%E3%83%BB%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AB%E3%81%AF%E3%80%81%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E4%BD%9C%E5%8B%95%E3%81%99%E3%82%8B%E9%9B%BB%E6%B0%97%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%A7%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AF%E9%81%8E%E8%B2%A0%E8%8D%B7%E3%81%BE%E3%81%9F%E3%81%AF%E7%9F%AD%E7%B5%A1%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E3%81%98%E3%82%8B%E9%81%8E%E9%9B%BB%E6%B5%81%E3%81%AB%E3%82%88%E3%82%8B%E9%9B%BB%E6%B0%97%E5%9B%9E%E8%B7%AF%E3%81%AE%E6%90%8D%E5%82%B7%E3%81%8B%E3%82%89%E9%9B%BB%E6%B0%97%E5%9B%9E%E8%B7%AF%E3%82%92%E4%BF%9D%E8%AD%B7%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CH1%20style%3D%22text-align%3A%20justify%3B%22%20id%3D%22toc-hId--1426701369%22%20id%3D%22toc-hId--503239883%22%3E%3CBR%20%2F%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FH1%3E%0A%3CH1%20style%3D%22text-align%3A%20justify%3B%22%20id%3D%22toc-hId-1060811464%22%20id%3D%22toc-hId-1984272950%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22BlockDiagram-CircuitBreaker-PNG%5B1%5D.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BlockDiagram-CircuitBreaker-PNG%5B1%5D.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F94520i78EC84A82CC67C82%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22BlockDiagram-CircuitBreaker-PNG%5B1%5D.png%22%20alt%3D%22BlockDiagram-CircuitBreaker-PNG%5B1%5D.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EBlockDiagram-CircuitBreaker-PNG%5B1%5D.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%80%E3%82%AF%E3%83%84%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2025px%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E3%82%AB%E3%83%86%E3%82%B4%E3%83%AA%E5%90%8D1%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%22%3E%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E8%A3%BD%E5%93%81URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-microcontrollers%2Fgeneral-purpose-mcus%2Fkv-series-cortex-m4-m0-plus-m7%2Fkinetis-kv1x-75-mhz-entry-level-3ph-foc-sensorless-motor-control-mcus-based-on-arm-cortex-m0-plus%3AKV1x%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-microcontrollers%2Fgeneral-purpose-mcus%2Fkv-series-cortex-m4-m0-plus-m7%2Fkinetis-kv1x-75-mhz-entry-level-3ph-foc-sensorless-motor-control-mcus-based-on-arm-cortex-m0-plus%3AKV1x%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%C2%AE%20Arm%20Cortex-M0%C2%AE%2B%7CKinetis%C2%AE%20KV1x%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20%7CNXP%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E8%A3%BD%E5%93%81%E8%AA%AC%E6%98%8E1%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%20text-align%3A%20justify%3B%22%3EKinetis%C2%AE%20KV1x%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AF%E3%80%81%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB16%E3%83%93%E3%83%83%E3%83%88A%2FD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9(ADC)%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%80%8112%E3%83%93%E3%83%83%E3%83%88%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E6%9C%80%E5%A4%A71.2%E3%83%A1%E3%82%AC%2F%E7%A7%92(MS%2Fs)%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%86%E3%81%BB%E3%81%8B%E3%80%8112%E3%83%93%E3%83%83%E3%83%88DAC%E3%81%A82%E3%81%A4%E3%81%AEACPM(%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%91%E3%83%AC%E3%83%BC%E3%82%BF)%E3%82%82%E6%90%AD%E8%BC%89%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%81%8E%E9%9B%BB%E6%B5%81%E3%81%8A%E3%82%88%E3%81%B3%E9%81%8E%E9%9B%BB%E5%9C%A7%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E6%A4%9C%E5%87%BA%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81BOM%E3%82%B3%E3%82%B9%E3%83%88%E3%82%92%E5%89%8A%E6%B8%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2025px%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E3%82%AB%E3%83%86%E3%82%B4%E3%83%AA%E5%90%8D1%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%22%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E8%AA%8D%E8%A8%BCIC%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E8%A3%BD%E5%93%81URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsecurity-and-authentication%2Fauthentication%2Fsecure-authenticator-ic-embedded-security-platform%3AA1006%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsecurity-and-authentication%2Fauthentication%2Fsecure-authenticator-ic-embedded-security-platform%3AA1006%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EA1006%20(%E8%8B%B1%E8%AA%9E)%20%7C%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%82%AA%E3%83%BC%E3%82%BB%E3%83%B3%E3%83%86%E3%82%A3%E3%82%B1%E3%83%BC%E3%82%BFIC%3A%E3%82%A8%E3%83%B3%E3%83%99%E3%83%87%E3%83%83%E3%83%89%E3%83%BB%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%83%BB%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%7CNXP%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E8%A3%BD%E5%93%81%E8%AA%AC%E6%98%8E1%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%20text-align%3A%20justify%3B%22%3E%0A%3CP%3EA1006%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E8%AA%8D%E8%A8%BCIC%20%E3%81%AF%E3%80%81%E9%AB%98%E5%AF%86%E5%BA%A6%E3%82%B5%E3%83%96%E3%83%9F%E3%82%AF%E3%83%AD%E3%83%B3%E6%8A%80%E8%A1%93%E3%81%A7%E8%A3%BD%E9%80%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E5%AE%89%E5%85%A8%E3%81%AA%E8%80%90%E3%82%BF%E3%83%B3%E3%83%91%E3%83%BC%E6%80%A7%E8%AA%8D%E8%A8%BCIC%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%BC%B7%E5%8A%9B%E3%81%AA%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8C%E8%87%AA%E7%A4%BE%E3%81%AE%E7%B4%94%E6%AD%A3%E8%A3%BD%E5%93%81%E3%81%AE%E4%BF%A1%E9%A0%BC%E6%80%A7%E3%82%92%E8%A8%BC%E6%98%8E%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%9B%AE%E7%9A%84%E3%81%A8%E3%81%97%E3%81%9F%E6%9A%97%E5%8F%B7%E5%8C%96%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%82%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2025px%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E3%82%AB%E3%83%86%E3%82%B4%E3%83%AA%E5%90%8D1%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%22%3ENTAG%20i2c%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E8%A3%BD%E5%93%81URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Frfid-nfc%2Fnfc-hf%2Fntag%2Fnfc-tags-for-electronics%2Fntag-ic-iplus-i-nfc-forum-type-2-tag-with-ic-interface%3ANTAG_I2C%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Frfid-nfc%2Fnfc-hf%2Fntag%2Fnfc-tags-for-electronics%2Fntag-ic-iplus-i-nfc-forum-type-2-tag-with-ic-interface%3ANTAG_I2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENTAG%20I2C%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E8%A3%BD%E5%93%81%E8%AA%AC%E6%98%8E1%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%20text-align%3A%20justify%3B%22%3E32%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E4%BF%9D%E8%AD%B7%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AF%E3%80%81%E3%83%9B%E3%83%BC%E3%83%A0%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8A%E3%82%88%E3%81%B3%E6%B0%91%E7%94%9F%E7%94%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BNFC%E3%81%AE%E5%AE%8C%E7%92%A7%E3%81%AA%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%A9%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82NT3H2111%20NFC%E3%82%BF%E3%82%B0IC%E3%81%AF%E3%80%81%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E9%9B%BB%E5%AD%90%E6%A9%9F%E5%99%A8%E3%81%AB%E3%82%BF%E3%83%83%E3%83%97%26amp%3B%E3%82%B4%E3%83%BC%E6%8E%A5%E7%B6%9A%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%9C%80%E9%80%9F%E3%81%8B%E3%81%A4%E6%9C%80%E3%82%82%E5%AE%89%E4%BE%A1%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%99%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2025px%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E3%82%AB%E3%83%86%E3%82%B4%E3%83%AA%E5%90%8D1%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%22%3E%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E8%A3%BD%E5%93%81URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Frf%2Frf-mixers%2Flow-power-fm-if-systems%2Flow-voltage-high-performance-mixer-fm-if-system-with-high-speed-rssi%3ASA636%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Frf%2Frf-mixers%2Flow-power-fm-if-systems%2Flow-voltage-high-performance-mixer-fm-if-system-with-high-speed-rssi%3ASA636%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESA636%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E8%A3%BD%E5%93%81%E8%AA%AC%E6%98%8E1%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%20text-align%3A%20justify%3B%22%3ESA636%E3%81%AF%E3%80%81%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%2F%E7%99%BA%E6%8C%AF%E5%99%A8%E3%80%812%E3%81%A4%E3%81%AE%E5%88%B6%E9%99%90%E4%B8%AD%E9%96%93%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%A2%E3%83%B3%E3%83%97%E3%80%81%E7%9B%B4%E4%BA%A4%E6%A4%9C%E5%87%BA%E5%99%A8%E3%80%81%E5%AF%BE%E6%95%B0%E5%8F%97%E4%BF%A1%E4%BF%A1%E5%8F%B7%E5%BC%B7%E5%BA%A6%E3%82%A4%E3%83%B3%E3%82%B8%E3%82%B1%E3%83%BC%E3%82%BF(RSSI)%E3%80%81%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%80%81%E5%BA%83%E5%B8%AF%E5%9F%9F%E3%83%87%E3%83%BC%E3%82%BF%E5%87%BA%E5%8A%9B%E3%80%81%E9%AB%98%E9%80%9FRSSI%E3%82%AA%E3%83%9A%E3%82%A2%E3%83%B3%E3%83%97%E3%82%92%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A0%E9%AB%98%E9%80%9FRSSI%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E4%BD%8E%E9%9B%BB%E5%9C%A7%E9%AB%98%E6%80%A7%E8%83%BD%E3%83%A2%E3%83%8E%E3%83%AA%E3%82%B7%E3%83%83%E3%82%AFFMIF%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%99%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2025px%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E3%82%AB%E3%83%86%E3%82%B4%E3%83%AA%E5%90%8D1%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%22%3ESMPS%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E8%A3%BD%E5%93%81URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fac-dc-solutions%2Fac-dc-controllers-with-integrated-power-switch%2Fhv-start-up-flyback-controller-with-integrated-mosfet-suitable-for-low-power-applications-up-to-11-w%3ATEA172X%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fac-dc-solutions%2Fac-dc-controllers-with-integrated-power-switch%2Fhv-start-up-flyback-controller-with-integrated-mosfet-suitable-for-low-power-applications-up-to-11-w%3ATEA172X%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETEA172x%E3%81%AE%7CNXP%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2037.7828%25%3B%20height%3A%2025px%3B%22%3E%E8%A3%BD%E5%93%81%E8%AA%AC%E6%98%8E1%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.7285%25%3B%20height%3A%2025px%3B%20text-align%3A%20justify%3B%22%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E9%AB%98%E9%9B%86%E7%A9%8D%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%80%8110mW%E6%9C%AA%E6%BA%80%E3%81%AE%E4%BD%8E%E7%84%A1%E8%B2%A0%E8%8D%B7%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%82%92%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%97%E3%80%81%E9%83%A8%E5%93%81%E7%82%B9%E6%95%B0%E3%82%92%E5%89%8A%E6%B8%9B%E3%81%97%E3%81%A6%E3%82%B3%E3%82%B9%E3%83%88%E5%8A%B9%E7%8E%87%E3%81%AE%E9%AB%98%E3%81%84%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E8%A8%AD%E8%A8%88%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%97%E3%80%81%E5%84%AA%E3%82%8C%E3%81%9F%E5%8A%B9%E7%8E%87%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E9%AB%98%E5%BA%A6%E3%81%AA%E5%88%B6%E5%BE%A1%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20style%3D%22text-align%3A%20justify%3B%22%20id%3D%22toc-hId--746642999%22%20id%3D%22toc-hId-176818487%22%3E%3CBR%20%2F%3E%E9%96%A2%E9%80%A3%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2037.6697%25%3B%22%3EDocument%20URL%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2059.8416%25%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%88%E3%83%AB%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2037.6697%25%3B%22%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11060.pdf%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11060.pdf%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.8416%25%3B%22%3E5%20W%E3%80%9C11%20W%E9%9B%BB%E6%BA%90%2F%20USB%E5%85%85%E9%9B%BB%E5%99%A8%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2037.6697%25%3B%22%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11276.zip%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11276.zip%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.8416%25%3B%22%3ENTAG%C2%AE%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E8%A8%AD%E8%A8%88%E3%82%AC%E3%82%A4%E3%83%89%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2037.6697%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fconfidential%2FAN11350%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fconfidential%2FAN11350%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENXP%20Semiconductors%20%3A%3A%20%E3%82%88%E3%82%8A%E3%82%B9%E3%83%9E%E3%83%BC%E3%83%88%E3%81%AA%E4%B8%96%E7%95%8C%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E5%AE%89%E5%85%A8%E3%81%AA%E6%8E%A5%E7%B6%9A%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2059.8416%25%3B%22%3ENTAG%C2%AE%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AA%E3%83%86%E3%82%A3%E7%BD%B2%E5%90%8D%E6%A4%9C%E8%A8%BC%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CH1%20style%3D%22text-align%3A%20justify%3B%22%20id%3D%22toc-hId-1740869834%22%20id%3D%22toc-hId--1630635976%22%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0URL%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-341526%22%20target%3D%22_blank%22%3E%E9%9B%BB%E5%8A%9B%E8%A6%8F%E5%88%B6%2F%E5%B8%82%E5%A0%B4%E5%8B%95%E5%90%91%E3%81%A8NXP%20AC%2FDC%E9%9B%BB%E6%BA%90%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-340253%22%20target%3D%22_blank%22%3ENFC%E3%83%87%E3%83%A2%20-%20%E6%83%85%E5%A0%B1%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%80%81%E5%9B%9E%E8%B7%AF%E5%9B%B3%20%3C%2FA%3E%20%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-333498%22%20target%3D%22_blank%22%3ENTAG%20I2C%20Plus%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20-%20Kinetis%20Freedom%E3%83%9C%E3%83%BC%E3%83%89%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20style%3D%22text-align%3A%20justify%3B%22%20id%3D%22toc-hId--66584629%22%20id%3D%22toc-hId-856876857%22%3E%3CBR%20%2F%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%8B%E3%82%89%E3%81%AE%E9%96%A2%E9%80%A3%E3%83%87%E3%83%A2%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%20font-weight%3A%20bold%3B%20font-size%3A%20inherit%3B%20padding%3A%205px%3B%22%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E9%96%A2%E9%80%A3%E3%83%87%E3%83%A2%20URL%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%20font-size%3A%20inherit%3B%20padding%3A%205px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fspace%2F11663%22%20target%3D%22_blank%22%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E8%AA%8D%E8%A8%BC%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1109000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎10-20-2020 09:19 AM
更新者:
