Audio and Video (A/V) Receiver
Description
An audio and video (A/V) receiver needs to be capable of managing different input sources. These devices integrate different solutions for media and entertaining content and different signals are being processed in a small period of time. The i.MX 8M applications processor supports protocols for typical application soundbars and A/V receivers: HDMI ports, SPDI ports, analog inputs and up to 16-channel analog outputs.
Block Diagram
Products
Category Name 1 Microprocessor
Product URL 1 i.MX 8M Applications Processor | Arm® Cortex®-A53, Cortex-M4 | 4K display resolution | NXP
Product Description 1
The i.MX 8M applications processor provides industry-leading audio, voice and video processing for applications that scale from consumer home audio to industrial building automation and mobile computers.
The video playback capabilities are 1080p60 with a 10-bit decoder, HEVC/H.265 decoder, AVC/H.264 Baseline along with VP8 decoder and encoder. The i.MX 8M Mini also has 5x Synchronous Audio Interfaces (SAI) and 8ch pulse density modulation inputs.
Category Name 2 Microcontroller
Product URL 1 LPC84x 30MHz|Arm® Cortex®-M0+|32-bit Microcontrollers (MCUs) | NXP
Product Description 1 This low-cost 32-bit MCU includes a 12-bit ADC, up to 54 GPIOs pins, TWO spi interfaces, along with one analog comparator. This power efficient device is a perfect MCU to work in specific multi-purpose tasks.
Category Name 3 Power Manager IC
Product URL 1 14-channel power management IC optimized for i.MX 8M | NXP
Product Description 1 The PF4210 is a high-performance PMIC that is optimized to power low-cost consumer applications with the i.MX 8M family of applications processors. It can provide power for a complete system, including applications processors, memory and system peripherals.
Category Name 4 Battery Charger
Product URL 1 MC34673 | Single-cell Battery Charger | NXP
Product Description 1 The MC34673 is a cost-effective fully-integrated battery charger for Li-Ion or Li-Polymer batteries. It tolerates an input voltage up to 28 V, which eliminates the input over-voltage-protection circuit required in handheld devices.
Category Name 5 Ethernet PHY Transceiver
Product URL 1 TJA1101 | 2nd generation PHY Transceiver | NXP
The TJA1101 offers a 100Mbit/s transmit and receive capability per port over up to at least 15m of unshielded twisted pair (UTP) cable, this transceiver is interoperable with any IEEE 100BASE-T1 and OABR compliant PHY. With a 6mm x 6mm the TJA1101 has the smallest footprint for a 100BASE-T1 PHY.
Category Name 6 USB switch
Product URL 1 High-speed USB 2.0 switch with enable | NXP
Product Description 1 The NX3DV221GM switch is designed for high-speed USB 2.0 signals in handset and consumer applications, such as cell phones, digital cameras, and notebooks with hubs or controllers with limited USB I/Os. This bidirectional switch offers little or no attenuation of the high-speed signals at the outputs. It is designed for low bit-to-bit skew and high channel-to-channel noise isolation.
Category Name 7 USB PD/Type-C Shield
Product URL 1 PTN5150 | NXP
Product Description 1 PTN5150 enables USB Type-C connector to be used in both host and device ends of the Type-C cable. It can support Type-C to USB legacy cables and adapters defined in USB Type-C Spec. PTN5150 can be configured to dual role, host, or device mode through external configuration pin or through I²C interface.
Category Name 8 USB Type C Logic
Product URL 1 NX3L4357 | NXP
Product Description 1 The NX3L4357 low-ohmic single-pole triple-throw analog switch suitable for use as an analog or digital 3:1 multiplexer/demultiplexer. Schmitt trigger action at the digital inputs makes the circuit tolerant to slower input rise and fall times.
Category Name 9 NTAG i2c interface
Product URL 1 NTAG I2C | NXP
Product Description 1 A 32-bit password protected interface, designed to be the perfect enabler for NFC in home-automation and consumer applications. The NT3H2111 NFC tag is the fastest, least expensive way to add tap-and-go connectivity to just about any electronic device.
Category Name 10 I²C Digital Temperature Sensor
Product URL 1 PCT2075: I2C-bus Fm+, 1 Degree C Accuracy | NXP
Product Description 1 The PCT2075 is a temperature-to-digital converter featuring a 11-bit ADC that offers a temperature resolution of 0.125 °C. The programmable temperature threshold and hysteresis set points during operation.
Category Name 11 Dual Bidirectional I²C-Bus Buffer
Product URL 1 PCA9600 | NXP
Product Description 1 The PCA9600 allows long buses to be driven in point-to-point or multipoint applications of up to 4000 pF, the PCA9600 also interfaces with opto-couplers to provide opto-isolation between I²C-bus nodes up to 1 MHz
Related Documentation
Document URL Title
https://www.nxp.com/docs/en/application-note/AN10364.pdf
Opto-electrical isolation of the I2C-bus
NXP Semiconductors :: Secure Connections for a Smarter World  NTAG® Originality Signature Validation
https://www.nxp.com/docs/en/nxp/application-notes/AN12407.pdf
LPC845 SPI Secondary Bootloader
https://www.nxp.com/docs/en/application-note/AN12410.pdf
Related Software
Related Software URL
MCUXpresso SDK | Software Development for Kinetis, LPC, and i.MX MCUs | NXP
Related Demos from Communities
Related Demos from Communities URL
i.MX Processors
i.MX Yocto Project: Frequently Asked Questions
i.MXDev Blog
Labels (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1121702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAudio%20and%20Video%20(A%2FV)%20Receiver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FAudio-and-Video-A-V-Receiver%2Fta-p%2F1121702%23toc-hId-382368537%22%20target%3D%22_blank%22%3EDescription%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FAudio-and-Video-A-V-Receiver%2Fta-p%2F1121702%23toc-hId--1425085926%22%20target%3D%22_blank%22%3EBlock%20Diagram%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FAudio-and-Video-A-V-Receiver%2Fta-p%2F1121702%23toc-hId-1742485277%22%20target%3D%22_blank%22%3EProducts%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FAudio-and-Video-A-V-Receiver%2Fta-p%2F1121702%23toc-hId--1891967341%22%20target%3D%22_blank%22%3ERelated%20Documentation%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FAudio-and-Video-A-V-Receiver%2Fta-p%2F1121702%23toc-hId-595545492%22%20target%3D%22_blank%22%3ERelated%20Software%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FAudio-and-Video-A-V-Receiver%2Fta-p%2F1121702%23toc-hId--1211908971%22%20target%3D%22_blank%22%3ERelated%20Demos%20from%20Communities%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId-382368537%22%20id%3D%22toc-hId-1297635701%22%3EDescription%3C%2FH1%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3EAn%20audio%20and%20video%20(A%2FV)%20receiver%20needs%20to%20be%20capable%20of%20managing%20different%20input%20sources.%20These%20devices%20integrate%20different%20solutions%20for%20media%20and%20entertaining%20content%20and%20different%20signals%20are%20being%20processed%20in%20a%20small%20period%20of%20time.%20The%20i.MX%208M%20applications%20processor%20supports%20protocols%20for%20typical%20application%20soundbars%20and%20A%2FV%20receivers%3A%20HDMI%20ports%2C%20SPDI%20ports%2C%20analog%20inputs%20and%20up%20to%2016-channel%20analog%20outputs.%3C%2FP%3E%0A%3CH1%20id%3D%22toc-hId--1425085926%22%20id%3D%22toc-hId--509818762%22%3E%3CBR%20%2F%3EBlock%20Diagram%3C%2FH1%3E%0A%3CH1%20id%3D%22toc-hId-1062426907%22%20id%3D%22toc-hId-1977694071%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Block-Diagram-AVReciever-PNG%5B1%5D.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Block-Diagram-AVReciever-PNG%5B1%5D.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F94497iF73393EFB606F657%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Block-Diagram-AVReciever-PNG%5B1%5D.png%22%20alt%3D%22Block-Diagram-AVReciever-PNG%5B1%5D.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EBlock-Diagram-AVReciever-PNG%5B1%5D.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FH1%3E%0A%3CH1%20id%3D%22toc-hId--745027556%22%20id%3D%22toc-hId-170239608%22%3E%26nbsp%3B%3C%2FH1%3E%0A%3CH1%20id%3D%22toc-hId-1742485277%22%20id%3D%22toc-hId--1637214855%22%3EProducts%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2036.1789%25%3B%22%3ECategory%20Name%201%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.5854%25%3B%22%3EMicroprocessor%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%22%3EProduct%20URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-8-processors%2Fi.mx-8m-family-armcortex-a53-cortex-m4-audio-voice-video%3Ai.MX8M%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-8-processors%2Fi.mx-8m-family-armcortex-a53-cortex-m4-audio-voice-video%3Ai.MX8M%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%208M%20Applications%20Processor%20%7C%20Arm%C2%AE%20Cortex%C2%AE-A53%2C%20Cortex-M4%20%7C%204K%20display%20resolution%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%22%3EProduct%20Description%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20text-align%3A%20justify%3B%22%3E%0A%3CP%3EThe%20i.MX%208M%20applications%20processor%20provides%20industry-leading%20audio%2C%20voice%20and%20video%20processing%20for%20applications%20that%20scale%20from%20consumer%20home%20audio%20to%20industrial%20building%20automation%20and%20mobile%20computers.%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3EThe%20video%20playback%20capabilities%20are%201080p60%20with%20a%2010-bit%20decoder%2C%20HEVC%2FH.265%20decoder%2C%20AVC%2FH.264%20Baseline%20along%20with%20VP8%20decoder%20and%20encoder.%20The%20i.MX%208M%20Mini%20also%20has%205x%20Synchronous%20Audio%20Interfaces%20(SAI)%20and%208ch%20pulse%20density%20modulation%20inputs.%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20id%3D%22toc-hId--64969186%22%20id%3D%22toc-hId-850297978%22%3E%26nbsp%3B%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2036.1789%25%3B%22%3ECategory%20Name%202%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.5854%25%3B%22%3EMicrocontroller%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%22%3EProduct%20URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-microcontrollers%2Fgeneral-purpose-mcus%2Flpc800-cortex-m0-plus-%2Flow-cost-microcontrollers-mcus-based-on-arm-cortex-m0-plus-cores%3ALPC84X%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-microcontrollers%2Fgeneral-purpose-mcus%2Flpc800-cortex-m0-plus-%2Flow-cost-microcontrollers-mcus-based-on-arm-cortex-m0-plus-cores%3ALPC84X%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELPC84x%2030MHz%7CArm%C2%AE%20Cortex%C2%AE-M0%2B%7C32-bit%20Microcontrollers%20(MCUs)%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%22%3EProduct%20Description%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20text-align%3A%20justify%3B%22%3EThis%20low-cost%2032-bit%20MCU%20includes%20a%2012-bit%20ADC%2C%20up%20to%2054%20GPIOs%20pins%2C%20TWO%20spi%20interfaces%2C%20along%20with%20one%20analog%20comparator.%20This%20power%20efficient%20device%20is%20a%20perfect%20MCU%20to%20work%20in%20specific%20multi-purpose%20tasks.%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20id%3D%22toc-hId--1872423649%22%20id%3D%22toc-hId--957156485%22%3E%26nbsp%3B%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2035.9756%25%3B%22%3ECategory%20Name%203%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.7886%25%3B%22%3EPower%20Manager%20IC%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2035.9756%25%3B%22%3EProduct%20URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.7886%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i.mx-applications-processors%2F14-channel-power-management-ic-optimized-for-i.mx-8m%3APF4210%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i.mx-applications-processors%2F14-channel-power-management-ic-optimized-for-i.mx-8m%3APF4210%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E14-channel%20power%20management%20IC%20optimized%20for%20i.MX%208M%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2035.9756%25%3B%22%3EProduct%20Description%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.7886%25%3B%20text-align%3A%20justify%3B%22%3EThe%20PF4210%20is%20a%20high-performance%20PMIC%20that%20is%20optimized%20to%20power%20low-cost%20consumer%20applications%20with%20the%20i.MX%208M%20family%20of%20applications%20processors.%20It%20can%20provide%20power%20for%20a%20complete%20system%2C%20including%20applications%20processors%2C%20memory%20and%20system%20peripherals.%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20id%3D%22toc-hId-615089184%22%20id%3D%22toc-hId-1530356348%22%3E%26nbsp%3B%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2035.7724%25%3B%22%3ECategory%20Name%204%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.9919%25%3B%22%3EBattery%20Charger%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2035.7724%25%3B%22%3EProduct%20URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.9919%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fbattery-management%2Fbattery-chargers%2F1.2-a-single-cell-li-ion-li-polymer-battery-charger%3AMC34673%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fbattery-management%2Fbattery-chargers%2F1.2-a-single-cell-li-ion-li-polymer-battery-charger%3AMC34673%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMC34673%20%7C%20Single-cell%20Battery%20Charger%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2035.7724%25%3B%22%3EProduct%20Description%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.9919%25%3B%20text-align%3A%20justify%3B%22%3EThe%20MC34673%20is%20a%20cost-effective%20fully-integrated%20battery%20charger%20for%20Li-Ion%20or%20Li-Polymer%20batteries.%20It%20tolerates%20an%20input%20voltage%20up%20to%2028%20V%2C%20which%20eliminates%20the%20input%20over-voltage-protection%20circuit%20required%20in%20handheld%20devices.%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20id%3D%22toc-hId--1192365279%22%20id%3D%22toc-hId--277098115%22%3E%26nbsp%3B%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2035.874%25%3B%22%3ECategory%20Name%205%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.8902%25%3B%22%3EEthernet%20PHY%20Transceiver%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2035.874%25%3B%22%3EProduct%20URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.8902%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-phy-transceivers%2F2nd-generation-ethernet-phy-transceivers-ieee-100base-t1-compliant%3ATJA1101%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-phy-transceivers%2F2nd-generation-ethernet-phy-transceivers-ieee-100base-t1-compliant%3ATJA1101%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETJA1101%20%7C%202nd%20generation%20PHY%20Transceiver%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2035.874%25%3B%22%3EProduct%20Description%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.8902%25%3B%22%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3EThe%20TJA1101%20offers%20a%20100Mbit%2Fs%20transmit%20and%20receive%20capability%20per%20port%20over%20up%20to%20at%20least%2015m%20of%20unshielded%20twisted%20pair%20(UTP)%20cable%2C%20this%20transceiver%20is%20interoperable%20with%20any%20IEEE%20100BASE-T1%20and%20OABR%20compliant%20PHY.%20With%20a%206mm%20x%206mm%20the%20TJA1101%20has%20the%20smallest%20footprint%20for%20a%20100BASE-T1%20PHY.%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2035.9756%25%3B%22%3ECategory%20Name%206%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.7886%25%3B%22%3EUSB%20switch%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2035.9756%25%3B%22%3EProduct%20URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.7886%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Fanalog-switches%2Fhigh-speed-usb-2.0-switch-with-enable%3ANX3DV221GM%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Fanalog-switches%2Fhigh-speed-usb-2.0-switch-with-enable%3ANX3DV221GM%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EHigh-speed%20USB%202.0%20switch%20with%20enable%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2035.9756%25%3B%22%3EProduct%20Description%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.7886%25%3B%20text-align%3A%20justify%3B%22%3EThe%20NX3DV221GM%20switch%20is%20designed%20for%20high-speed%20USB%202.0%20signals%20in%20handset%20and%20consumer%20applications%2C%20such%20as%20cell%20phones%2C%20digital%20cameras%2C%20and%20notebooks%20with%20hubs%20or%20controllers%20with%20limited%20USB%20I%2FOs.%20This%20bidirectional%20switch%20offers%20little%20or%20no%20attenuation%20of%20the%20high-speed%20signals%20at%20the%20outputs.%20It%20is%20designed%20for%20low%20bit-to-bit%20skew%20and%20high%20channel-to-channel%20noise%20isolation.%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20id%3D%22toc-hId-1295147554%22%20id%3D%22toc-hId--2084552578%22%3E%26nbsp%3B%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2036.1789%25%3B%22%3ECategory%20Name%207%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.5854%25%3B%22%3EUSB%20PD%2FType-C%20Shield%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%22%3EProduct%20URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fusb-interfaces%2Fusb-type-c-true-plugn-play%2Fusb-pd-phy-and-cc-logic%2Fcc-logic-for-usb-type-c-applications%3APTN5150%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fusb-interfaces%2Fusb-type-c-true-plugn-play%2Fusb-pd-phy-and-cc-logic%2Fcc-logic-for-usb-type-c-applications%3APTN5150%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPTN5150%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%22%3EProduct%20Description%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20text-align%3A%20justify%3B%22%3EPTN5150%20enables%20USB%20Type-C%20connector%20to%20be%20used%20in%20both%20host%20and%20device%20ends%20of%20the%20Type-C%20cable.%20It%20can%20support%20Type-C%20to%20USB%20legacy%20cables%20and%20adapters%20defined%20in%20USB%20Type-C%20Spec.%20PTN5150%20can%20be%20configured%20to%20dual%20role%2C%20host%2C%20or%20device%20mode%20through%20external%20configuration%20pin%20or%20through%20I%C2%B2C%20interface.%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20id%3D%22toc-hId--764571248%22%20id%3D%22toc-hId-150695916%22%3E%26nbsp%3B%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2036.1789%25%3B%22%3ECategory%20Name%208%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.5854%25%3B%22%3EUSB%20Type%20C%20Logic%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%22%3EProduct%20URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Fanalog-switches%2Flow-ohmic-single-pole-triple-throw-analog-switch-with-enable-input%3ANX3L4357%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Fanalog-switches%2Flow-ohmic-single-pole-triple-throw-analog-switch-with-enable-input%3ANX3L4357%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENX3L4357%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%22%3EProduct%20Description%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20text-align%3A%20justify%3B%22%3EThe%20NX3L4357%20low-ohmic%20single-pole%20triple-throw%20analog%20switch%20suitable%20for%20use%20as%20an%20analog%20or%20digital%203%3A1%20multiplexer%2Fdemultiplexer.%20Schmitt%20trigger%20action%20at%20the%20digital%20inputs%20makes%20the%20circuit%20tolerant%20to%20slower%20input%20rise%20and%20fall%20times.%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20style%3D%22font-weight%3A%20bold%3B%22%20id%3D%22toc-hId-1722941585%22%20id%3D%22toc-hId--1656758547%22%3E%26nbsp%3B%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2036.1789%25%3B%22%3ECategory%20Name%209%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.5854%25%3B%22%3ENTAG%20i2c%20interface%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%22%3EProduct%20URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%22%3E%3CA%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Frfid-nfc%2Fnfc-hf%2Fntag%2Fnfc-tags-for-electronics%2Fntag-ic-iplus-i-nfc-forum-type-2-tag-with-ic-interface%3ANTAG_I2C%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Frfid-nfc%2Fnfc-hf%2Fntag%2Fnfc-tags-for-electronics%2Fntag-ic-iplus-i-nfc-forum-type-2-tag-with-ic-interface%3ANTAG_I2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENTAG%20I2C%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%22%3EProduct%20Description%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20text-align%3A%20justify%3B%22%3EA%2032-bit%20password%20protected%20interface%2C%20designed%20to%20be%20the%20perfect%20enabler%20for%20NFC%20in%20home-automation%20and%20consumer%20applications.%20The%20NT3H2111%20NFC%20tag%20is%20the%20fastest%2C%20least%20expensive%20way%20to%20add%20tap-and-go%20connectivity%20to%20just%20about%20any%20electronic%20device.%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2024px%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2036.1789%25%3B%20height%3A%2024px%3B%22%3ECategory%20Name%2010%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.5854%25%3B%20height%3A%2024px%3B%22%3EI%C2%B2C%20Digital%20Temperature%20Sensor%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%20height%3A%2024px%3B%22%3EProduct%20URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20height%3A%2024px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fic-digital-temperature-sensors%2Fic-bus-fm-plus-1-degree-c-accuracy-digital-temperature-sensor-and-thermal-watchdog%3APCT2075%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fic-digital-temperature-sensors%2Fic-bus-fm-plus-1-degree-c-accuracy-digital-temperature-sensor-and-thermal-watchdog%3APCT2075%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPCT2075%3A%20I2C-bus%20Fm%2B%2C%201%20Degree%20C%20Accuracy%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2075px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%20height%3A%2075px%3B%22%3EProduct%20Description%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20text-align%3A%20justify%3B%20height%3A%2075px%3B%22%3EThe%20PCT2075%20is%20a%20temperature-to-digital%20converter%20featuring%20a%2011-bit%20ADC%20that%20offers%20a%20temperature%20resolution%20of%200.125%20%C2%B0C.%20The%20programmable%20temperature%20threshold%20and%20hysteresis%20set%20points%20during%20operation.%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20id%3D%22toc-hId--84512878%22%20id%3D%22toc-hId-830754286%22%3E%26nbsp%3B%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2024px%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2036.1789%25%3B%20height%3A%2024px%3B%22%3ECategory%20Name%2011%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.5854%25%3B%20height%3A%2024px%3B%22%3EDual%20Bidirectional%20I%C2%B2C-Bus%20Buffer%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%20height%3A%2024px%3B%22%3EProduct%20URL%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20height%3A%2024px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fother-interfaces%2Fdual-bidirectional-bus-buffer%3APCA9600%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fother-interfaces%2Fdual-bidirectional-bus-buffer%3APCA9600%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPCA9600%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2075px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%20height%3A%2075px%3B%22%3EProduct%20Description%201%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20text-align%3A%20justify%3B%20height%3A%2075px%3B%22%3EThe%20PCA9600%20allows%20long%20buses%20to%20be%20driven%20in%20point-to-point%20or%20multipoint%20applications%20of%20up%20to%204000%20pF%2C%20the%20PCA9600%20also%20interfaces%20with%20opto-couplers%20to%20provide%20opto-isolation%20between%20I%C2%B2C-bus%20nodes%20up%20to%201%20MHz%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20id%3D%22toc-hId--1891967341%22%20id%3D%22toc-hId--976700177%22%3E%3CBR%20%2F%3ERelated%20Documentation%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2024px%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2036.1789%25%3B%20height%3A%2024px%3B%22%3EDocument%20URL%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2061.5854%25%3B%20height%3A%2024px%3B%22%3ETitle%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%20height%3A%2024px%3B%22%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN10364.pdf%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN10364.pdf%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20height%3A%2024px%3B%22%3EOpto-electrical%20isolation%20of%20the%20I2C-bus%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2075px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%20height%3A%2075px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fconfidential%2FAN11350%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fconfidential%2FAN11350%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENXP%20Semiconductors%20%3A%3A%20Secure%20Connections%20for%20a%20Smarter%20World%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20text-align%3A%20justify%3B%20height%3A%2075px%3B%22%3ENTAG%C2%AE%20Originality%20Signature%20Validation%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2075px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%20height%3A%2075px%3B%22%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fnxp%2Fapplication-notes%2FAN12407.pdf%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fnxp%2Fapplication-notes%2FAN12407.pdf%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20text-align%3A%20justify%3B%20height%3A%2075px%3B%22%3ELPC845%20SPI%20Secondary%20Bootloader%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2075px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2036.1789%25%3B%20height%3A%2075px%3B%22%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-%3C%2FA%3Enote%2FAN12410.pdf%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2061.5854%25%3B%20text-align%3A%20justify%3B%20height%3A%2075px%3B%22%3ELPC845%20SPI%20Secondary%20Bootloader%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20id%3D%22toc-hId-595545492%22%20id%3D%22toc-hId-1510812656%22%3E%3CBR%20%2F%3ERelated%20Software%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%3ERelated%20Software%20URL%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools%2Fmcuxpresso-software-development-kit-sdk%3AMCUXpresso-SDK%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools%2Fmcuxpresso-software-development-kit-sdk%3AMCUXpresso-SDK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMCUXpresso%20SDK%20%7C%20Software%20Development%20for%20Kinetis%2C%20LPC%2C%20and%20i.MX%20MCUs%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH1%20id%3D%22toc-hId--1211908971%22%20id%3D%22toc-hId--296641807%22%3E%3CBR%20%2F%3ERelated%20Demos%20from%20Communities%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%20font-weight%3A%20bold%3B%20font-size%3A%20inherit%3B%20padding%3A%205px%3B%22%3ERelated%20Demos%20from%20Communities%20URL%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%20font-size%3A%20inherit%3B%20padding%3A%205px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fspace%2F2004%22%20target%3D%22_blank%22%3Ei.MX%20Processors%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%20font-size%3A%20inherit%3B%20padding%3A%205px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94023%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%20Project%3A%20Frequently%20Asked%20Questions%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%20font-size%3A%20inherit%3B%20padding%3A%205px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fimxdev.gitlab.io%2F%22%20href%3D%22https%3A%2F%2Fimxdev.gitlab.io%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MXDev%20Blog%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1121702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EBlock%20Diagrams%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ESmart%20Home%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎10-20-2020 09:21 AM
Updated by:
