ADK Library (Based On FRDM-KL26Z Board.)
Android Open Accessory support allows external USB hardware (an Android USB accessory) to interact with an Android-powered device in a special accessory mode. When an Android-powered powered device is in accessory mode, the connected accessory acts as the USB host (powers the bus and enumerates devices) and the Android-powered device acts in the USB accessory role.
This ADK library is based on NXP Kinetis Microcontroller KL26, It implements some functions to communicate with android phone.
添付
コメント
Where can I find the ADK library and sample project referenced in the K26ADKlib_User_Guide document?
The file is embedded in the document, in the last page.
Santiago
Where can I get the ADK Library source code to compile it for other devices (e.g for MK26 or MIMXRT1051) for example?
The example only includes the lib file.
評価なし
バージョン履歴
最終更新日:
‎01-19-2015 12:52 PM
更新者:
