Throttle Issue Buggy3
1,590 次查看
GuyHorne
I'm having an issue with the buggy3 when I upload the sample application from here steering works fine but no throttle
In contrast when I swap around the PWM signals PWM Wiring (I know its wrong in this picture) the throttle works but no steering.
Also worth noting I have got the buggy working OK with the controller except for an issue with non zero throttle ie throttle stick needs to be held down while the buggy is armed otherwise it will go full throttle.
Any idea what could be causing this?
Specs:
FMUK66
Fly sky fsi6 transmitter
0 回复数
