programming PN5180 development kit (OM25180FDK) by LPC on the board
1,227 次查看
steve_wilson
I wanted to run provided examples like basicloop on the pn5180 board, I used mcuxpresso ide.
the kit I use is PN5180 development kit (OM25180FDK).
I created hex file, I could not find anyway to load on kit.
is there anything to load this hex file except using lpc debugger (LPC-Link 2) ?
Thank you
1 回复
1,215 次查看
nxf58474
Hope you are doing well. You need an external debugger to program the LPC on the board. In this case, the best would be to use a LPC-Link2.
Ricardo
