operating distance
operating distance
1,863 次查看
salmabay
Hello I am looking for a quick answer please
I am using CLRC663 NFC reader, I have designed the matching circuit of my Antenna with 23 Ohm target impedance, however the operating distance is not as required, it is 2 cm using NTAG216 and 0.5 cm using the MIFARE DESFIRE EV1 Tag.
 The diameter of my round antenna is  2cm
- I would like to ask why the operating distance different when using the MIFARE card, and it is better with NTAG.
- Is it possible to improve the result? and how?
Thank you
1,709 次查看
stephanie_m
By any chance, have you checked the different webinars available in the page regarding the antenna design Online Training|NXP ? There are six of them which might give you the best guide regarding the antenna design recommendations.
Estephania
