nxp PN512 NFC frontend module with imx6sx
1,601件の閲覧回数
pavansingpatil
we have PN512 NFC frontend configured with imx6sx soc using i2c bus. I would like to know about linux driver support for kernel-4.9 and and userspace tool to test this and how to get started?
there seems to be NFC support available in kernel-4.9 but not for PN512.
any information on this would be very helpful. Thanks.
タグ(4)
2 返答(返信)
1,351件の閲覧回数
jimmychan
Although this is for PN7150, the step for porting the PN512 to i.MX BSP is the same.
https://community.nxp.com/docs/DOC-331906
1,351件の閲覧回数
pavansingpatil
hi,
Thanks for reply.
If i understand correctly PN512 is just NFC frontend without controller and in built firmware unlike PN7150.
I followed the steps and able to compile and load the pn5xx_i2c kernel modules.
running nfcDemoApp result into segmentation fault.
root@pavan:/home# ls /dev/pn544
/dev/pn544
root@pavan:/home# ./nfcDemoApp write --type=Text -l en -r "Test"
## NFC demo ##
## Write mode activated ##
SNEP Client Register Callback Failed
Leaving ...
root@pavan:/home# ./nfcDemoApp poll
## NFC demo ##
## Poll mode activated ##
Leaving ...
root@pavan:/home# ./nfcDemoApp push -t URI -u http://www.nxp.com
## NFC demo ##
## Push mode activated ##
... press enter to quit ...
Leaving ...
Pavan
