Replace PN532 command with NFC Reader Libraly
hiroshishimizu
I used PN 532 so far, but I decided to use PN 5180 anew.
I think that "PN 5180 uses" NFC Reader Libraly ".
How can I replace the "InDataExchange" and "InCommunicateThru" commands I used with PN 532 in "NFC Reader Libraly"?
Labels (2)
Kan_Li
Hi Hiroshi-san,
Is this question from the same customer of your case# 00155563? I saw you created a new case for this question, but just want to make sure , Please kindly clarify.
Thanks for your patience!
Kan
