ntag i2c silence mode
puneethjagadees
Hello All,
I am new to NFC, I am working on NTAG I2C plus and I want to put it into silence mode. I am using peek and poke software and trying to set the bit I2C_RST_ON_OFF, but the NTAG is still detectable. What am I doing wrong? Please help me out here.
I am getting this error when I try to config the register from session registers.
Puneeth
Kan_Li
Hi Puneeth,
Do you want to put NTAG I2C into Halt state? if so , you have to send HLTA command to put the device into this state which can only be existed with a WUPA command.
Wish it helps.
Kan Li
