how to ProcessCardMode in NFC
rla00220
i use ncf3340.
In p2p mode, sending an ndef message to the phone using an antenna was successful.
But it failed to send ndef message in card mode.
The function in T4T_NDEF_EMU_Next does not seem to produce a proper message.
In fact, I checked the logs and found that pCmd matches only T4T_NDEF_EMU_APP_Select. CC_Select, NDEF_Select, and so on. What can I do?
help me... thanks.
IvanRuiz
As you may know the information about NCF3340 is under NDA, because of this the information about this device cannot be handled on public community.
Please help me to contact your local distributor to get support for this part, otherwise please let me know in case you do not have one assigned.
Have a nice day.
Ivan.
