PN5180 register read error by default
4,406 次查看
liumanjinkobe
Now i cann't get the right value from any register use command 0x04.
I think the busy line is right.
I describe my trouble in attachment in detail.
Thanks for your help.
Liu
标签 (1)
标记 (2)
6 回复数
4,200 次查看
jimmychan
The content of the register is returned in the 4 byte response.
4,200 次查看
liumanjinkobe
Yes, but i cann't get the right response.
4,200 次查看
jimmychan
I saw you only receive one byte.
According to the datasheet, this is the recommendation for the BUSY line handling by the host:
1. Assert NSS to Low
2. Perform Data Exchange
3. Wait until BUSY is high
4. Deassert NSS
5. Wait until BUSY is low
Have you try to read/write the other register? e.g. system_config
4,200 次查看
liumanjinkobe
The BUSY line is used to indicate that the system is BUSY and cannot receive any data
from a host. Recommendation for the BUSY line handling by the host:
4. Deassert NSS
i want to know Perform Data Exchange is send 0x04+0x00+32bit response or only send 0x04.
Because after i send 0x04,the busy has become high.
4,200 次查看
jimmychan
Yes, when BUSY is high, need to deassert the NSS.
4,200 次查看
liumanjinkobe
Yes,other registers are 0xffffffff also.
Now i want to send 0x04 command to get the 32bit of 0x00 register.
After send 0x04, i can find busy line has become high,Now i want to know if i should Deassert
NSS to let  busy line recover low.And then i can send 0x00  to get the response.
For i know if busy line is high,PN5180 cann't get 0x00 data.
Thanks.
