Reference design file for MFRC522
3,184 次查看
Ram_RAM
Hi ,
In our design we are planing to use this NFC IC "MFRC522". so requsting to share any reference design file to understand the circuit design.
Thanks.
3,081 次查看
Tomas_Parizek
Hello Ram_RAM,
I think that this page could help you: https://www.nxp.com/products/rfid-nfc/mifare-hf/mifare-desfire/pegoda-contactless-smart-card-reader-...
This reader is based on the MFRC523 which is essentially the same as MFRC522. The difference is only in supported standards.
The reference design can be found here:
Tomas
4 回复数
3,156 次查看
Tomas_Parizek
Hello Ram_RAM,
As the MFRC522 is not recommended for new designs I would suggest going for MFRC63003HN
MFRC63003HN: https://www.nxp.com/part/MFRC63003HN#/
The MFRC63003HN is based on the CRLC663 family, so there is a full package of support materials (including reference design) available.
CRLC663: https://www.nxp.com/products/rfid-nfc/nfc-hf/nfc-readers/clrc663-iplus-i-family-high-performance-nfc...
Tomas
3,117 次查看
Ram_RAM
Hi Tomas,
Good day!,
Thank you for your suggestion,
But if there is some reference design please share with me, because we have already brought this IC .
So we are planning to go with this now , in later we will study the IC that you suggest.
Ram
标记 (3)
3,082 次查看
Tomas_Parizek
Hello Ram_RAM,
Tomas
3,076 次查看
Ram_RAM
Hi Tomas,
Good day!,
Thanks a lot .....
