Read user memory with Global Crypto Header Activated (ICODE DNA)
ソリューションへジャンプ
2,468件の閲覧回数
jonasumander
With the following settings
Key0, Key1 and Key2 set.
Key0 and Key1 privileges set to Read and Write.
Key2 and Key3 privileges set to none.
All 4 key headers set to Active and Locked.
Global Crypto header set to Activated.
With these settings I can still read from user memory without doing an authentication. What setting am I missing?
Note that I can do a mutual authentication and then also read from user memory, but that is working as I would expect.
2,332件の閲覧回数
jonasumander
Just to answer my own question read the document (rev 3.0) chapter 8.5.3.2 and 8.5.3.3 in case anyone else run in to the same confusion as I did.
2 返答(返信)
2,333件の閲覧回数
jonasumander
2,332件の閲覧回数
Jonathan_Iglesias
Dear Jonas Umander,
this kind of information is under NDA to get help I invite you to sign an NDA with one of our distributors,  my apologies for this inconvenience.
Jonathan
