Problem with 1-turn Antenna Coil using Antenna Tool
2,054件の閲覧回数
duong_duy_trong
Hi NXP experts,
I am Trong, from STYL
We design our NFC antenna with only 1 turn on TOP Layer, and the information as picture belowAntenna_coil-1.png
I want to check the value of my antenna equivalent circuit and then the reference matching circuit value.
Unfortunately, our antenna only has 1 turn and I can not input the right value for property "Gap between tracks" to get the most accurate result.
Could you please help me find the solution?
Trong
ラベル(2)
2 返答(返信)
1,956件の閲覧回数
stephanie_m
Let me report the issue you are having.
Estephania
1,956件の閲覧回数
stephanie_m
While this gets fixed, you can check the excel file for your application but you will need to write your data .
Estephania
