Power Management for PN544 chip based NFC
2,509 次查看
anjalikkrishna
Hi ,
 I am working on NFC with PN544 NFC chip on Linux 3.10.53. The NFC functionality is working fine with the driver which I have downloaded from below link which is provided by NXP
git clone https://github.com/NXPNFCLinux/nxp-pn5xx.git .
Now I am doing Power Management in my embedded board where NFC is a integral module. Currently the NFC driver does not support suspend resume routines.
Is there any new versions or release for NFC drivers from NXP with PM implemented?
Thannks & Regards,
Anjali
标记 (3)
2,296 次查看
zanget
hi, Anjalik.
i'd like to ask how did you make it work and how many functionalitys you can used?
is there any document about the functionalitys it can provided?
2,296 次查看
Kan_Li
Hi Anjali,
As I know, PN544 supports Power down mode, is that the function you are looking for? Please kindly help to clarify.
Kan
