Pn512 Tag Emulation Callibration
3,530件の閲覧回数
ilanseeder
I'm emulating a Mifare Ultralight tag using Pn512.
When I use it by itself, it works well.
I encounter a problem where on some readers, when I put the Pn512 together with a regular tag, the reader dean't see the other tag and doesn't recognize a collision (it does recognize a collision of 2 regular tags)
On another reader, the opposite happens - the reader sees the tag but not the Pn512.
I suppose this happens because of antenna difference and different Tx settings between the tag and Pn512 (unless you can advise me otherwise).
I can't change the antenna, I suppose I need to calibrate the tx .I know I can do this using the GsnOffReg register, and other registers),
The question is - is there a module or a project that can callibrate the tx according to the field?
Is there any other info I can use to solve this problem?
Thanks!
5 返答(返信)
3,310件の閲覧回数
Kan_Li
For calibration, we recommend the tool of MINIVNA pro, and you may refer to http://cache.nxp.com/docs/en/application-note/AN11535.pdf?fsrch=1&sr=1&pageNum=1 for details.
Hope that helps,
Kan
3,310件の閲覧回数
salmabay
Is it possible to use Mini VNA Tiny for calibration? or it should be pro?
3,310件の閲覧回数
Kan_Li
Must be Mini VNA pro for calibration.
Kan
3,310件の閲覧回数
salmabay
Can you please explain briefly, why?
3,310件の閲覧回数
Kan_Li
The expert just told me that is a MUST option. but I understand it is due to the working range, and you may refer to PRO vs Tiny | mRS mini Radio Solutions  for more details.
Hope that helps,
Kan
