PN7462 Adapting example code for PN7412
1,650件の閲覧回数
Vlatakomarac
In our application we are using PN7412 from the PN7462 family as an interface to a smart card.
I am trying to adapt the PN7462 example code phExCcid to make it work on PN7412 i.e. I am trying to disable all contactless functionalities and leave intact the contact smart card functionalities.
I have noticed that the source code has defined a macro called: PHFL_APP_DISABLE_CLIF and that it can be used to tell the preprocessor to ignore contactless card funcionalities with #ifdef / #ifndef directives.
My question: Is it enough to define this macro so I can use the PN7462 example code on our PN7412 IC? Or are there any more additional changes I need to make?
Any advice would be helpfull. Thank you in advance!
Nikola Vulinovic
1,554件の閲覧回数
danielchen
Hi Nikola Vulinovic:
For phExCcid demo, there is a CtifOnly_DebugPN7462 build target for your reference. PHFL_APP_DISABLE_CLIF=1 is enabled in this option.
