PN7220 Android support
qiuquanfeng
Hi, hope you have a good day.
I plan to use PN7220 as a pos payment application. Read the datasheet of NFC chip PN7220, the chip supports Android 13-14, I would like to ask whether it can support Android 12?
#PN722 #NFC
KaiLi
Hello @qiuquanfeng
PN7220 support Android onwards 13, if you must start to Android 12 then recomended to switch PN7160.
KaiLi
Hello @qiuquanfeng
qiuquanfeng
Hi KellyLi
Thank you very much for your reply!
For POS terminal applications, must EMVCo standards be met? Do you have any other chips you recommend?
KaiLi
Hello @qiuquanfeng
PN5190 recommends to you, but it cannot be running on Android.
%3CLINGO-SUB%20id%3D%22lingo-sub-1977664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPN7220%20Android%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1977664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20hope%20you%20have%20a%20good%20day.%3C%2FP%3E%3CP%3EI%20plan%20to%20use%20PN7220%20as%20a%20pos%20payment%20application.%20Read%20the%20datasheet%20of%20NFC%20chip%20PN7220%2C%20the%20chip%20supports%20Android%2013-14%2C%20I%20would%20like%20to%20ask%20whether%20it%20can%20support%20Android%2012%3F%3C%2FP%3E%3CP%3E%23PN722%20%23NFC%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1978199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PN7220%20Android%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1978199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F189489%22%20target%3D%22_blank%22%3E%40qiuquanfeng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPN5190%20recommends%20to%20you%2C%20but%20it%20cannot%20be%20running%20on%20Android.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1978087%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PN7220%20Android%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1978087%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CSPAN%3EKellyLi%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20your%20reply!%3CBR%20%2F%3EFor%20POS%20terminal%20applications%2C%20must%20EMVCo%20standards%20be%20met%3F%20Do%20you%20have%20any%20other%20chips%20you%20recommend%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1977792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PN7220%20Android%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1977792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F189489%22%20target%3D%22_blank%22%3E%40qiuquanfeng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPN7220%20support%20Android%20onwards%2013%2C%20if%20you%20must%20start%20to%20Android%2012%20then%20recomended%20to%20switch%20PN7160.%3C%2FP%3E%3C%2FLINGO-BODY%3E
