PN7150 stability testing fault
ethan_dang1
Platform: PN7150 & Qualcomm MSM8909 & Android 7
Process:Cards are detected periodically every three seconds
Symptoms:After a period of time, the card cannot be detected, other card also not work, after switch NFC ON ->OFF->ON card can be detected again.No error messages are found in the log
Has anyone come across it? Can you share what could be the cause? Thank you!
KaiLi
Hello @ethan_dang1
Thanks for sharing and contacting us and interested in the NXP products.
So, I'd like to know what if you extended the POLLING period, the same phenomenon?
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002s4fRlAAI
The portal allows access to the full details of the case, including the previous communication.
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
Kelly
Technical Support
NXP Semiconductor
KaiLi
Hello @ethan_dang1
If you extend polling without any more crashes, then there is probably a problem with the matching timeout between the test application what you're used and PN7150. It is difficult to debug and match this timeout because the application is not NXP and its specific implementation is not clear. The only solution is to try to adjust the polling interval.
Kelly
Technical Support
NXP Semiconductor
ethan_dang1
