PN7150 reduce power to avoid touchscreen interference
832 次查看
V_Palacio
Contributor V
We have a device with a PN7150 reading RFID cards through a screen with a capacitive touch. Host is a Linux embedded ARM (iMX6) with libnfc-nci-linux.
When RFID is active, it generates an interfence than generates random touch events.
Disabling some technologies from polling (HOST_LISTEN_TECH_MASK), I can reduce this interferences, but I cannot get ride of  all of them.
I'm trying to reduce radiated power from the NFC antenna, in order to see if I can eliminate false touch events, but I'm not finding any way to do this.
1 There is no function in libnfc-nci API to set power values
2 I've not found any parameter in the config files (libnfc-nci.conf libnfc-nxp-init.conf libnfc-nxp-pn548.conf) that can set power values.
I suspect NXP_CORE_CONF array can modify some config to do the trick, I cannot find any clue in the chip manual as what can change to do this.
Can someone point me in the right direction for this?
0 回复数
