PN7150 TAG READING
PN7150 TAG READING
mohamednacer_sa
Hello NXP ,
did anyone work with pn7150 , I did not know  how to start configuring it ....i read the documentation but i need help in some points ...added to that ,how can i transmit data from the antenna to the I2C interface ????
stephanie_m
hello,
I believe that you can use this webinar to understand a little more about the usage of the controller kits . You can use one of the examples as a base to migrate it to the host you are using.
Regards ,
Estephania
mohamednacer_sa
hey thank you for your answer ,
I already see this web webinar but it did not give a good idea
stephanie_m
I answered in the other support request
Regards ,
Estephania
