PN532 Library
PN532 Library
2,646 次查看
Rodri_Rock
Hello people, my name is Rodrigo, I have a project with a PN532 v3 module using a PIC microcontroller and I2c communication. Does anyone have a C language library for the CCS compiler? Since the Arduino library is very extensive for PIC, I only need to read a mifare tag or card.
2 回复数
1,679 次查看
nelloann
Hi Rodri, have you solved? i need help with a similar idea and i appreciate if you help me. Thank you
2,635 次查看
ramprakash09
While there isn't that much specific detailed availabe for C library for the CCS compiler as per my knowledge, you can refer to the PN532's data sheet and application notes for detailed information on how to interface with the device.
