PN5180 interrupt handling in Library SW
1,708 次查看
smiwa
Could you let me know how the library software detect and handle with IRQ from PN5180?
I like to know where jump table and its handler are written in source code in Llibrary:NFCReaderLibraryForCLEV663B-04.030.00.011627.
Thank you for your supports!
   S. Miwa
1,497 次查看
smiwa
Hi Kan san,
Very sorry... It is typo. The device is PN5180 and its library is also for PN5180. Not for CLEV663.
Thank you very much!
best regards,
   S. Miwa
1,497 次查看
Kan_Li
Hi S.Miwa,
Thanks for the information! Please kindly refer to the following for details.
Hope that helps,
Kan
1,497 次查看
Kan_Li
Hi S.Miwa,
Would you please clarify which chip you are referring to? PN5180 or CLEV663? Thanks for your patience!
B.R
Kan
