PN512 replacement
PN512 replacement
1,397件の閲覧回数
ampspoland
I am representing AMPS Poland. Until now we have used processor PN512. Could you provide us with information regarding processor that can replace PN512 (next generation?). I would also need some information regarding technical support in Poland.
Leszek Piotrowski
タグ(1)
1,174件の閲覧回数
Kan_Li
Hi Leszek Piotrowski,
It depends on your application. If you only use it for reading cards, RC663 is recommended, but if you use it for P2P as well, PN5180 is recommended.
For local tech support, please kindly contact your local DFAE for help. You may refer to Distributor Network|NXP  for details.
Hope that helps,
Kan
