P2P mode through 14443
bhargaviunnamat
Hi Team,
Please clarify if NT3H1101 will support sharing GPS data through NFC. We would like to share the Mobile Phone location through NFC. As NT3H1101 supports 14443 read/write mode, shall i able to read data from mobile phone of GPS data? Or do i need to use PEER to PEER mode tag? If yes, Kindly suggest P2P supported I2C TAGS for my application.
Tags (3)
stephanie_m
I believe there is a terminology confusion between the P2P, tag, reader, etc.
Could you please watch the following webinars which will help to clarify the concepts?
NFC Essentials Webinar|NXP
NFC Applications and Use Cases|NXP
I believe you will find also there which will be the best product to use, nonetheless, if you have any further question, let me know.
Estephania
bhargaviunnamat
Thanks Martinez. We have gone through the two webiner session. We have selected NTAG I2C TAG - NT3H1101 , which is best suite for our present application. Which is connected to Controller and NFC antenna, such that it will able to communicate to/from Phone APP.
bhargaviunnamat
Please help this out.
