NXP Reader library with crypto components running on lpc1768
1,522 次查看
ktanikel
We have the export controlled version of the NXP Reader library from the docstore. We have an application running on an lpc1768 microcontroller that uses the NXP Reader library. However, we are unable to use some of the crypto functionality because the crypto library comes in a .lib format and seems to be targeted for Windows applications, so we are unable to link to it. Is there a way for us to get around this?
Thanks.
标记 (1)
1,221 次查看
estephania_mart
Are by any chance, are you using LPCXpresso ?
If you are, have you check this post How to create a new LPC project using LPCOpen and LPCXpresso;  there you can find how to import libraries into a project.
Also, please remember that all the information regarding docstore files should not be posted here in the public community but should be asked through a case that you can enter in Support|NXP or with your DBM in case you have one.
Estephania
