NXP NFC Library v07.10.00 and Linux 6.6
1,666件の閲覧回数
eldar
Are there any plans to upgrade the NFC library to support Linux 6.6.x ?
In Linux 6.6.x,  using GPIO through the /sys/class/gpio filesystem is no longer supported, thus the NFC library cannot be used.  The NFC library is using that API to control PN5180 Frontend Reset, Busy, IRQ and DWL signals.
ラベル(2)
2 返答(返信)
1,653件の閲覧回数
kowalski_analysis
Maybe this guide helps:
https://community.nxp.com/t5/NFC-Knowledge-Base/Porting-PN7160-NCI2-stack-to-Raspberry-Pi-5-OS-Bookw...
It explains how to port the NFC library to support the newer kernel version.
1,638件の閲覧回数
eldar
Thanks, I will look into it!
