I have several questions about the restricted AREA_1 memory section of the NTAG5 devices:
Thanks for the answers and best regards !
Solved! Go to Solution.
Hello @rfid_profi
Hope you are doing well.
The SET PASSWORD command has to be executed just once for the related password if the IC is powered.
Regarding PP_AREA_1, you would need to read block 3Fh to get PP_AREA_1 value.
Eduardo.
Hello @rfid_profi
Eduardo.
