NTAG 424 GetVersion - Part 2 - 911c error
2,610 次查看
authways
I am trying to call GetVersion - Part 2 command (90af000000).
I am getting 911c error randomly but this error is not documented in the NT4H2421Gx documentation.
Any idea what this means? In this case is it safe to just call the command again until it returns something other than 911c?
标签 (1)
标记 (2)
3 回复数
2,480 次查看
authways
It seems like I needed to select some file? I though this command did not need that.
2,466 次查看
KaiLi
Hello @authways
Get Version does not need to select some files, on my side did the same test everything is ok, the below is for your reference.
kelly
2,571 次查看
KaiLi
Hello @authways
Thanks for contacting us and using the NXP products.
Please try the following steps:
Step 1: Field On + Activate Idle + RATS+PPS
Step 2: GetVersion
Please feel free to contact us if any questions.
kelly
