NFC antenna
NFC antenna
Simayacikel
I designed a double layer NFC antenna using NXP's antenna tool. I had to make the antenna size smaller. The equivalent inductance in the tool came out to be approximately 0.6uH. This value is very small, I have read comments on forums such as it should be over 1uH. Could you give advice on this matter? Can it be said that 0.6uH is too small a value and the antenna will not work?
Thank you.
Fabian_R
Hello, my name is Fabian, I've been assigned to support your case.
I appreciate your interest in our products.
Could you please provide me with a little more information regarding which product you are using? We have different recommendations depending on the product your solution is based on.
Fabian
Simayacikel
Thank you i solved my problem.
Fabian_R
Fabian
