J-Link Commander Cannot Download Image to PN7642 (Some Units Previously Working Now Failing)
1,580件の閲覧回数
axis-zhao
Hi all,
I'm encountering an issue when using J-Link Commander to download firmware to the PN7642 .
Summary:
* Total units: 36
* 22 units: working normally
* 14 units: consistently failing
Important note:
All units were previously programmed successfully with our earlier firmware. The issue appeared when attempting to reprogram them with a newer image.
Issue description:
For the failing units, J-Link Commander cannot connect to the target device. The log output is shown below:
Connecting to target via SWD
Found SW-DP with ID 0x6BA02477
DPIDR: 0x6BA02477
CoreSight SoC-400 or earlier
Scanning AP map to find all available APs
AP[1]: Stopped AP scan as end of AP map seems to be reached
AP[0]: AHB-AP (IDR: 0x84770001, ADDR: 0x00000000)
Iterating through AP map to find AHB-AP to use
AP[0]: Skipped. Could not read CPUID register
Attach to CPU failed. Executing connect under reset.
Failed to power up DAP
DPIDR: 0x6BA02477
Error occurred: Could not connect to the target device.
For troubleshooting steps visit: https://wiki.segger.com/J-Link_Troubleshooting
Additional information:
  • I have tried issuing the r (reset) command in J-Link Commander, but it does not resolve the issue
  • Same hardware setup is used for both working and failing units (same J-Link, same board, same procedure)
  • All failing units show identical behavior
Observations:
  • Failure occurs during SWD connection:
    • Cannot read CPUID
    • DAP power-up fails
  • Working units remain fully programmable
Questions:
  1. Are there known mechanisms in PN7642 that can disable or lock SWD after programming?
  2. Is there a recommended way recover access (e.g., connect under reset, mass erase, boot pin configuration)?
  3. Could this indicate the device entering a protected or low-power state that blocks debug access?
Any guidance on how to recover these devices or further debug the root cause would be greatly appreciated.
Thanks in advance!
2 返答(返信)
1,560件の閲覧回数
axis-zhao
Hello @KaiLi,
Thanks for the suggestion to try J-Flash.
I've attempted to use J-Flash with my PN7642, but I'm consistently running into connection failures. The behavior is similar to what I observed with J-Link Commander - J-Flash is unable to establish a connection to the target. (See the attached file, 'j_flash_connection_error.png').
Are there any additional steps or recovery methods you would recommend to regain access?
Any guidance would be greatly appreciated!
Thanks!
I
1,563件の閲覧回数
KaiLi
Hello @axis-zhao
Please try J-Flash, it works fine on my side, like attach picture.
%3CLINGO-SUB%20id%3D%22lingo-sub-2344508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EJ-Link%20Commander%E3%81%8CPN7642%E3%81%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%88%E4%BB%A5%E5%89%8D%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%A7%E4%B8%8D%E5%85%B7%E5%90%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2344508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3EJ-Link%20Commander%3C%2FSTRONG%3E%3C%2FEM%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FPN7642%2Fpd-p%2FPN7642%22%20class%3D%22lia-product-mention%22%20data-product%3D%221588-1%22%20target%3D%22_blank%22%3EPN7642%3C%2FA%3E%E3%81%AB%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%A6%81%E7%B4%84%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E*%20%E7%B7%8F%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E6%95%B0%EF%BC%9A36%3C%2FP%3E%3CP%3E*%2022%E5%8F%B0%EF%BC%9A%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%2014%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%EF%BC%9A%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AB%E5%A4%B1%E6%95%97%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%87%8D%E8%A6%81%E3%81%AA%E6%B3%A8%E6%84%8F%E4%BA%8B%E9%A0%85%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AF%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E9%9A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E8%AA%AC%E6%98%8E%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E5%85%B7%E5%90%88%E3%81%AE%E3%81%82%E3%82%8B%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81J-Link%20Commander%E3%81%AF%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%AD%E3%82%B0%E5%87%BA%E5%8A%9B%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8C%60%E3%80%8D%3C%2FP%3E%3CP%3ESWD%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%3CBR%20%2F%3EID%200x6BA02477%E3%81%AESW-DP%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A%200x6BA02477%3CBR%20%2F%3E%20CoreSight%20SoC400%E4%BB%A5%E5%89%8D%E3%81%AE%E8%A3%BD%E5%93%81%3CBR%20%2F%3E%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20AP%5B1%5D%3A%20AP%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E7%B5%82%E7%AB%AF%E3%81%AB%E9%81%94%E3%81%97%E3%81%9F%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81AP%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20AP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x84770001%E3%80%81ADDR%3A%200x00000000)%3CBR%20%2F%3E%20AP%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E5%8F%8D%E5%BE%A9%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BAHB-AP%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%3CBR%20%2F%3EAP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EDAP%E3%81%AE%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EID%200x6BA02477%E3%81%AESW-DP%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A%200x6BA02477%3CBR%20%2F%3E%20CoreSight%20SoC400%E4%BB%A5%E5%89%8D%E3%81%AE%E8%A3%BD%E5%93%81%3CBR%20%2F%3E%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20AP%5B1%5D%3A%20AP%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E7%B5%82%E7%AB%AF%E3%81%AB%E9%81%94%E3%81%97%E3%81%9F%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81AP%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20AP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x84770001%E3%80%81ADDR%3A%200x00000000)%3CBR%20%2F%3E%20AP%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E5%8F%8D%E5%BE%A9%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BAHB-AP%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%3CBR%20%2F%3EAP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EDAP%E3%81%AE%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwiki.segger.com%2FJ-Link_Troubleshooting%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwiki.segger.com%2FJ-Link_Troubleshooting%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%80%8C%60%E3%80%8D%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3EJ-Link%20Commander%E3%81%A7r%EF%BC%88%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%EF%BC%89%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%A8%E6%95%85%E9%9A%9C%E3%81%97%E3%81%9F%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E3%80%81%E5%90%8C%E3%81%98%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%A7%8B%E6%88%90%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%88%E5%90%8C%E3%81%98J-Link%E3%80%81%E5%90%8C%E3%81%98%E3%83%9C%E3%83%BC%E3%83%89%E3%80%81%E5%90%8C%E3%81%98%E6%89%8B%E9%A0%86%EF%BC%89%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%95%85%E9%9A%9C%E3%81%97%E3%81%9F%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E5%90%8C%E3%81%98%E6%8C%99%E5%8B%95%E3%82%92%E7%A4%BA%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%E8%A6%B3%E5%AF%9F%E7%B5%90%E6%9E%9C%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3ESWD%E6%8E%A5%E7%B6%9A%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CUL%3E%3CLI%3ECPUID%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLI%3E%3CLI%3EDAP%E3%81%AE%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%E4%BD%9C%E6%A5%AD%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AF%E5%AE%8C%E5%85%A8%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8B%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%E8%B3%AA%E5%95%8F%3A%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3EPN7642%E3%81%AB%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E5%BE%8C%E3%81%ABSWD%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%81%8D%E3%82%8B%E6%97%A2%E7%9F%A5%E3%81%AE%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E5%9B%9E%E5%BE%A9%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%EF%BC%88%E4%BE%8B%EF%BC%9A%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%80%81%E4%B8%80%E6%8B%AC%E6%B6%88%E5%8E%BB%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%94%E3%83%B3%E8%A8%AD%E5%AE%9A%E3%81%AA%E3%81%A9%EF%BC%89%3C%2FLI%3E%3CLI%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E4%BF%9D%E8%AD%B7%E7%8A%B6%E6%85%8B%E3%81%BE%E3%81%9F%E3%81%AF%E4%BD%8E%E9%9B%BB%E5%8A%9B%E7%8A%B6%E6%85%8B%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%BE%A9%E6%97%A7%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%82%92%E3%81%95%E3%82%89%E3%81%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E4%BD%95%E3%81%8B%E3%81%94%E5%8A%A9%E8%A8%80%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%A4%A7%E5%A4%89%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2344508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%83%BB%E3%82%BF%E3%82%B0%E3%83%BB%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EHITAG%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BCIC%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E7%94%A8MIFARE%20SAM%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ENFC%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ENFC%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%BB%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ENFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%83%BB%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2344661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20J-Link%20Commander%20Cannot%20Download%20Image%20to%20PN7642%20(Some%20Units%20Previously%20Working%20Now%20Failing)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2344661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205266%22%20target%3D%22_blank%22%3E%40KaiLi%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3EJ-Flash%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%94%E6%8F%90%E6%A1%88%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPN7642%E3%81%A7J-Flash%E3%82%92%E4%BD%BF%E3%81%8A%E3%81%86%E3%81%A8%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%8E%A5%E7%B6%9A%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E9%A0%BB%E7%B9%81%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%8C%99%E5%8B%95%E3%81%AF%E3%80%81%E7%A7%81%E3%81%8CJ-Link%20Commander%E3%81%A7%E8%A6%B3%E5%AF%9F%E3%81%97%E3%81%9F%E6%8C%99%E5%8B%95%E3%81%A8%E4%BC%BC%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82J-Flash%E3%81%AF%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%A8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A2%BA%E7%AB%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%EF%BC%88%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8Cj_flash_connection_error.png%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%EF%BC%89%3C%2FP%3E%3CP%3E%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E5%9B%9E%E5%BE%A9%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E4%BB%96%E3%81%AB%E6%8E%A8%E5%A5%A8%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%82%84%E5%BE%A9%E6%97%A7%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%A4%A7%E5%A4%89%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2344608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20J-Link%20Commander%20Cannot%20Download%20Image%20to%20PN7642%20(Some%20Units%20Previously%20Working%20Now%20Failing)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2344608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261323%22%20target%3D%22_blank%22%3E%E3%80%81%40axis-zhao%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EJ-Flash%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%B7%BB%E4%BB%98%E7%94%BB%E5%83%8F%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorKaiLi_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
