Is there available CAD for TED Kit 2?
1,339件の閲覧回数
ponus_adam
I really need some dimension about the equipment.
And what is the maximum and minimum distance which the transponder can detect? I didn't find in release notes.
Thank you!
1,290件の閲覧回数
Kan_Li
Please kindly refer to https://www.nxp.com/docs/en/user-guide/UM10276.pdf , in which you may find the PCB info as below:
The maximum and minimum distance which the transponder can detect also depends on the antenna design on the tag side, so it could not specified.
Kan
