How to emulate iso 7816-3 contact card using PN7462?
811件の閲覧回数
vil
I want to use PN7462 (rather the board https://www.nxp.com/part/PNEV7462C )to emulate EMV contact (ISO 7816-3) and contactless card.  I understand that it can emulate contactless (14443-A) EMV card, but no mention about contact card emulation anywhere.
I also don't find questions anywhere in NXP community for contact card emulation, so, I am wondering whether it is something very easy that I don't know.
Kindly point me to the resources I can read and use.  Thank you.
5 返答(返信)
765件の閲覧回数
vil
ok, understood that pn7462 doesn't emulate contact card.  What other options available?  Thank you.
753件の閲覧回数
KaiLi
Hello @vil
If what you want is CT card emulation, then I'm really sorry, there is no option for that.
658件の閲覧回数
vil
Thank you.  I understand that there is no direct solution exist to emulate contact card.
I am still looking for ways to achieve this and looking for help from this community.  Deeply appreciate and thank the community for suggestions using existing ICs  to achieve ISO/IEC 7816-3 contact card emulation. (for e.g., as 7462 generates the clock, does ETU calculations, keeps counters, can I use it to achieve contact emulation through some software programming?  )
551件の閲覧回数
KaiLi
Hello @vil
CT cards should be impossible to simulate. At least NXP has never made such an attempt.
802件の閲覧回数
KaiLi
Hello @vil
PN7462 does not support CT emulation.
