High impedance MISO PN512
jpcazzasa
I am thinking to use the frontend PN512 with SPI interface. But I need to know if the MISO pin will go to high impedance when NSS is high (chip not enabled), because I am sharing this bus with other devices.
Kan_Li
Hi Juan,
I am checking with our expert team for your query, and will let you know when I have any more information.
Thanks for your patience!
Kan
