HTRC110 authentication support
2,515件の閲覧回数
sk5
Does HTRC110 reader support key and password authentication with Hitag-S transponders? I couldn't find any useful info about it.
2 返答(返信)
2,365件の閲覧回数
Sabina_Bruce
The HTRC110 does not have any specific key/authentication commands. However, I recommend that using the read/write commands you interpret the  data coming from the HiTag S transponder.
In the HITAG S datasheet in section 5.2.3 you will find the registers that contain the password bytes for authentication mode. And in section 8.1 you will find the general description of the states and how the authentication mode is selected.
Due to the datasheet being under NDA, I am not able to provide the specifics. If you do not have NDA, please let me know so I can provide the instructions.
Sabina
2,365件の閲覧回数
sk5
Just sent a NDA request. Thank you!
