HTRC110 PSK/FSK tag reading Capabilities
alasa995
I need to use HTRC110 to read FSK/PSK modulated tokens (mainly HID MicroProx), I found out that the chip is incapable of dealing with such modulation, any confirmation and explanation as to why? such modulation should be simple to handle. Any other alternative from NXP?
SergiyK
Good afternoon alasa995! I'm also doing this research. How far have you gotten? Best regards, Sergey.
alasa995
Hi, I managed to make the chip work to decode FSK modulation, all that was needed was to tweak the config for the IC.
%3CLINGO-SUB%20id%3D%22lingo-sub-1848856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHTRC110%20PSK%2FFSK%20tag%20reading%20Capabilities%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20need%20to%20use%20HTRC110%20to%20read%20FSK%2FPSK%20modulated%20tokens%20(mainly%20HID%20MicroProx)%2C%20I%20found%20out%20that%20the%20chip%20is%20incapable%20of%20dealing%20with%20such%20modulation%2C%20any%20confirmation%20and%20explanation%20as%20to%20why%3F%20such%20modulation%20should%20be%20simple%20to%20handle.%20Any%20other%20alternative%20from%20NXP%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HTRC110%20PSK%2FFSK%20tag%20reading%20Capabilities%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGood%20afternoon%20alasa995!%20I'm%20also%20doing%20this%20research.%20How%20far%20have%20you%20gotten%3F%20Best%20regards%2C%20Sergey.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HTRC110%20PSK%2FFSK%20tag%20reading%20Capabilities%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20I%20managed%20to%20make%20the%20chip%20work%20to%20decode%20FSK%20modulation%2C%20all%20that%20was%20needed%20was%20to%20tweak%20the%20config%20for%20the%20IC.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
