For using an Explore NFC Board with Raspberry Pi 3 should we have to install separate device drivers apart from the existing ones? And Will it support libnfc?
1,749 次查看
akshaykumarsr
Will it also come with NeardAL inbuilt in it?
1,539 次查看
Kan_Li
Hi Akshay Kumar S R,
If you start with the Raspbian “Jessie” image from the download page of the Raspberry Pi foundation , you have to install packages before going ahead, you may get all the packages from EXPLORE-NFC - Exclusive from element14|NXP , please kindly refer to http://www.nxp.com/documents/application_note/AN11480.pdf  for more details.
Hope that helps,
Kan
1,539 次查看
akshaykumarsr
Thanks for the information Kan_Li.
