Filter NFC Cockpit log information and add required timestamping
BrunoSenzio
We would like to share a way and script to create custom logs form the NFC Cockpit GUI, could be of use if timing is needing for detecting reading distances.
Just copy all the information from the log window and create a random file to then filter out with a custom script.
Hoping it to be of use.
Best,
BSSB
BrunoSenzio
# NFC Cockpit Parsing script
import csv
if __name__ == "__main_":
with open('log_nfc.txt') as f:
log = f.readlines()
output = []
for line in log:
if "INFO" in line:
time_data = line[12:20]
hour, min, sec = time_data.split(':')
output.append([hour, min, sec])
fields = ['Hour', 'Minute', 'Second']
with open('parsed_nfc.csv', 'w') as f:
write = csv.writer(f)
write.writerow(fields)
write.writerows(output)
