CLRC66303 Problem with SIGOUT
1,678件の閲覧回数
Thomas7
I am using the kit board of the CLRC66303.
According to the page 45 of the datasheet, the signal SIGOUT can be extracted. However, I have some problems to see it. Can you help me please ?
Thomas.
2 返答(返信)
1,665件の閲覧回数
Fabian_R
Thank you for your interest in our products.
You should be able to see the signal in the interface test point J301 for SIGOUT and GND. Could you tell me what is your setup for performing this test?
Fabian
1,652件の閲覧回数
Thomas7
Basically, I am trying to read the pin SIGOUT and according to the datasheet p.44, I changed the registers in order to have the SIGOUT signal (Sigpro_in_sel = 1, TxCon.TxSel = 1) and by changing the SIGOUT signal I want on the interface, I only got either no changes or one change which is I think not what I should be having.
Thanks for helping me.
Thomas.
