EXPLORE on Raspberry Pi 3 with Windows IoT
christianhammer
Hello there!
I already mailed Jimmy and he asked me to create a new thread on the NFC Community to receive the best support.
I currently have the NFC NXP Explore Module that should work fine on Raspbian but the company that those modules are for, require Windows and it is simply impossible for me to write a Driver by myself.
The IT banned all Solutions involving Linux/Android and many other OS so I’m basically stuck with Windows 10 IoT.
It is supposed to read encrypted cards to trigger a login procedure.
Could you provide a driver and a small guide how to implement this card on my raspberry with WinIoT?
Working with Mifare (see bottom line)
Big thank you in advance!
Product page: http://de.farnell.com/nxp/explore-nfc-ww/erweiterungsplatine-raspberry/dp/2445690​
christianhammer
NXP NFC Expert wrote in e-mail:
we don't have plug'N play solution for Windows IoT with PN512. Customer could port the ReaderLib in this environment to create NFC application.
Easier and faster solution is to use PN7120 with OM5577 Raspberry Pi demo kit (see related documentation) or the next coming PN7150 with OM5578 Raspberry Pi demo kit (see related documentation http://cache.nxp.com/documents/application_note/AN11758.pdf). Indeed, those NFC Controller are natively supported by win10 inbox driver, and we are related providing guidelines for driver installation here.
