Creating an audio trail
1,326 次查看
ianbinnie
I am a beginner with NFC's. I am using a Nexus % android phone to set up an audio trail in a museum. I have recorded something my voice using an app called Hi-Q MP3. I want to use tag to prompt a play back of the recording. I am using Tagwriter. When I go into My Datasets I can see the content and it asks me to tap an NFC. When I do this the audio app takes over but does not play the recording. What can I do to move on from this?
1,284 次查看
Kan_Li
Hi Lan,
Actually it is not a NFC topic, and this issue might be related with the audio app, maybe you have to pass some parameter to it before launching it for automatically recording.
Hope that helps,
Kan
