CLRC663 plus with I2C interface
MartinHo
I need to used the CLRC66303HN with the I2C interface.
Is there an example how to convert the NxpNfcRdLib_RC663 to use the I2C?
The DAL seems to support only the SPI interface.
jimmychan
Unfortunately, there is no I2C based example.
Solved: CLRC663/610 and i2c communication examples - NXP Community
MartinHo
A little bit disappointing, that You promote a Component with I2C and do not deliver a possibility to us this interface.
I will try to open a case.
Martin
%3CLINGO-SUB%20id%3D%22lingo-sub-2173128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECLRC663%20plus%20with%20I2C%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2173128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20need%20to%20used%20the%20CLRC66303HN%20with%20the%20I2C%20interface.%3C%2FP%3E%3CP%3EIs%20there%20an%20example%20how%20to%20convert%20the%20NxpNfcRdLib_RC663%20to%20use%20the%20I2C%3F%3C%2FP%3E%3CP%3EThe%20DAL%20seems%20to%20support%20only%20the%20SPI%20interface.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2174881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CLRC663%20plus%20with%20I2C%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EA%20little%20bit%20disappointing%2C%20that%20You%20promote%20a%20Component%20with%20I2C%20and%20do%20not%20deliver%20a%20possibility%20to%20us%20this%20interface.%3C%2FP%3E%3CP%3EI%20will%20try%20to%20open%20a%20case.%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3CP%3EMartin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2174853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CLRC663%20plus%20with%20I2C%20interface%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EUnfortunately%2C%20there%20is%20no%20I2C%20based%20example.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC%2FCLRC663-610-and-i2c-communication-examples%2Fm-p%2F1186886%22%20target%3D%22_blank%22%3ESolved%3A%20CLRC663%2F610%20and%20i2c%20communication%20examples%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
