Authentication Timeout [Mifare classic] [NP5180]
2,568 次查看
jaime_feller
My application uses 2 sets of keys, the routine usually checks if it can authenticate with the primary keys and if that fails go for the secondary keys, everything works okay, but the timeout of phalMfc_Sw_Authenticate is a bit to long (about 320 ms until I get the PH_ERR_IO_TIMEOUT), there is anyway to shorten this timeout?
thanks for your help
2 回复数
2,404 次查看
Kan_Li
Hi Jaime,
Would you please help to check address 0x12 in the EEPROM of PN5180 regarding the firmware version? Thanks for your patience!
Kan
1,846 次查看
SiMu
is there a solution to this problem. I have exactly the same behavior as described above
