Android 15 NXP BSP 1.2.0 and NFC support
4,532件の閲覧回数
robertosartori
Hi!
I'm following this document to integrate the changes needed to support the PN7160 NFC chip on Android:
https://www.nxp.com/docs/en/application-note/AN14608.pdf
I'm currently running Android 15 1.2.0 on a iMX8MP which is based on the Android 15 r14 tag
The document above includes the links to the software packages based on the Android 15 r1 release: unfortunately, it seems between the 2 releases there have been some change in the NFC Android stack which makes the two incompatible.
For example, I get these errors trying to build the packages/apps/Nfc repo:
packages/apps/Nfc/src/com/android/nfc/NfcService.java:1762: error: NfcService.NfcAdapterService is not abstract and does not override abstract method fetchActiveNfceeList() in INfcAdapter
    final class NfcAdapterService extends INfcAdapter.Stub {
packages/apps/Nfc/src/com/android/nfc/NfcService.java:2164: error: method does not override or implement a method from a supertype
        @Override
packages/apps/Nfc/src/com/android/nfc/NfcService.java:2260: error: method does not override or implement a method from a supertype
        @Override
packages/apps/Nfc/src/com/android/nfc/NfcService.java:2544: error: method does not override or implement a method from a supertype
        @Override
packages/apps/Nfc/src/com/android/nfc/NfcService.java:2608: error: method does not override or implement a method from a supertype
        @Override
packages/apps/Nfc/src/com/android/nfc/cardemulation/CardEmulationManager.java:584: error: CardEmulationManager.CardEmulationInterface is not abstract and does not override abstract method isEuiccSupported() in INfcC
    final class CardEmulationInterface extends INfcCardEmulation.Stub {
packages/apps/Nfc/src/com/android/nfc/cardemulation/CardEmulationManager.java:883: error: recoverRoutingTable(int) in CardEmulationManager.CardEmulationInterface cannot implement recoverRoutingTable(int) in INfcCard
        public boolean recoverRoutingTable(int userHandle) {
  return type boolean is not compatible with void
packages/apps/Nfc/src/com/android/nfc/cardemulation/CardEmulationManager.java:855: error: method does not override or implement a method from a supertype
        @Override
packages/apps/Nfc/src/com/android/nfc/cardemulation/CardEmulationManager.java:882: error: method does not override or implement a method from a supertype
        @Override
The first error is caused by this commit which introduces an API not present on the Android 15 r1 release:
https://android.googlesource.com/platform/frameworks/base/+/9fa0481604f727087a7d752c32ff7789372fbb88
Are the latest BSPs from NXP not supported by the current NXP NFC software support package?
Thanks!
Roberto
9 返答(返信)
4,106件の閲覧回数
nicolalg
@jimmychan is there any update on this topic? Any feedback is appreciated. Thank you.
4,304件の閲覧回数
Arrow_AE_KingLiu
@Jimmy
Any update about this case. One of my customers encounter the same issue when they porting the PN7160 to android OS 15 .
Below is the log :
packages/apps/Launcher3/src/com/android/launcher3/responsive/HotseatSpecsProvider.kt:54:9: warning: parameter 'dimensionType' is never used
dimensionType: DimensionType,
packages/apps/Launcher3/src/com/android/launcher3/util/LauncherLayoutBuilder.kt:170:13: warning: the corresponding parameter in the supertype 'ItemTarget' is named 'children'. This may cause problems when calling this function with named arguments.
childrenIgnored: List<Node>?
[ 42% 55590/131966] //packages/apps/Nfc:NfcNci javac [common] (priority: 22)
FAILED: out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/NfcNci.jar out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno.srcjar
rm -rf "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/classes" "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno" "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno.srcjar.tmp" "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/srcjars" "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/NfcNci.jar.tmp" && mkdir -p "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/classes" "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno" "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/srcjars" && out/host/linux-x86/bin/zipsync -d out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/srcjars -l out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/srcjars/list -f "*.java" out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/app/pendingintent.srcjar out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/content/component_name.srcjar out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/content/intent.srcjar out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/nfc/aid_group.srcjar out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/nfc/apdu_service_info.srcjar out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/nfc/card_emulation.srcjar out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/nfc/ndef.srcjar out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/nfc/nfc_fservice_info.srcjar out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/nfc/nfc_service.srcjar out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/os/patternmatcher.srcjar out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/os/persistablebundle.srcjar out/soong/.intermediates/frameworks/base/framework-nfc-javastream-protos/gen/gensrcs/frameworks/base/core/proto/android/privacy.srcjar out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/gen/android/R.srcjar && (if [ -s out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/srcjars/list ] || [ -s out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/NfcNci.jar.rsp ] ; then out/host/linux-x86/bin/soong_javac_wrapper prebuilts/jdk/jdk21/linux-x86/bin/javac -J-Xmx4096M -J-XX:OnError="cat hs_err_pid%p.log" -J-XX:CICompilerCount=6 -J-XX:+UseDynamicNumberOfGCThreads -J-XX:+TieredCompilation -J-XX:TieredStopAtLevel=1 -Xmaxerrs 9999999 -encoding UTF-8 -sourcepath "" -g -XDskipDuplicateBridges=true -XDstringConcat=inline -proc:none -Xlint:-dep-ann --system=out/soong/.intermediates/build/soong/java/core-libraries/stable-core-platform-api-stubs-system-modules/android_common/system -classpath out/soong/.intermediates/vendor/nxp/frameworks/nfc/com.nxp.nfc/android_common/turbine-combined/com.nxp.nfc.jar:out/soong/.intermediates/vendor/nxp/frameworks/nfc/com.nxp.nfc/android_common/repackaged-jarjar/turbine/com.nxp.nfc.jar:out/soong/.intermediates/vendor/nxp/frameworks/emvco/com.nxp.emvco/android_common/turbine-combined/com.nxp.emvco.jar:out/soong/.intermediates/vendor/nxp/frameworks/emvco/com.nxp.emvco/android_common/repackaged-jarjar/turbine/com.nxp.emvco.jar:out/soong/.intermediates/frameworks/base/nfc/framework-nfc.impl/android_common/jarjar/turbine/framework-nfc.jar:out/soong/.intermediates/frameworks/base/framework/android_common/turbine-combined/framework.jar:out/soong/.intermediates/frameworks/base/framework/android_common/repackaged-jarjar/turbine/framework.jar:out/soong/.intermediates/frameworks/base/omapi/aidl/android.se.omapi-V1-java/android_common/turbine-combined/android.se.omapi-V1-java.jar:out/soong/.intermediates/prebuilts/sdk/current/androidx/m2repository/androidx/annotation/annotation-jvm/1.9.0-rc01/androidx.annotation_annotation/android_common/combined/androidx.annotation_annotation.jar:out/soong/.intermediates/prebuilts/sdk/current/androidx/m2repository/androidx/appcompat/appcompat/1.8.0-alpha01/androidx.appcompat_appcompat/android_common/turbine-combined/androidx.appcompat_appcompat.jar:out/soong/.intermediates/packages/apps/Nfc/bluetooth-protos-nfc-enums-java-gen/android_common/turbine-combined/bluetooth-protos-nfc-enums-java-gen.jar:out/soong/.intermediates/prebuilts/sdk/current/extras/material-design-x/com.google.android.material_material/android_common/turbine-combined/com.google.android.material_material.jar:out/soong/.intermediates/frameworks/libs/modules-utils/java/com/android/internal/util/modules-utils-fastxmlserializer/android_common/turbine-combined/modules-utils-fastxmlserializer.jar:out/soong/.intermediates/frameworks/libs/modules-utils/java/com/android/modules/utils/modules-utils-shell-command-handler/android_common/turbine-combined/modules-utils-shell-command-handler.jar:out/soong/.intermediates/system/libsysprop/srcs/PlatformProperties/android_common/turbine-combined/PlatformProperties.jar:out/soong/.intermediates/packages/apps/Nfc/proto/nfc-event-log-proto/android_common/turbine-combined/nfc-event-log-proto.jar:out/soong/.intermediates/packages/apps/Nfc/flags/nfc_flags_lib/android_common/turbine-combined/nfc_flags_lib.jar -source 17 -target 17 -d out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/classes -s out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno @out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/NfcNci.jar.rsp @out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/srcjars/list ; fi ) && out/host/linux-x86/bin/soong_zip -jar -o out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno.srcjar.tmp -C out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno -D out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno && out/host/linux-x86/bin/soong_zip -jar -o out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/NfcNci.jar.tmp -C out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/classes -D out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/classes && if ! cmp -s "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/NfcNci.jar.tmp" "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/NfcNci.jar"; then mv "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/NfcNci.jar.tmp" "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/NfcNci.jar"; fi && if ! cmp -s "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno.srcjar.tmp" "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno.srcjar"; then mv "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno.srcjar.tmp" "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/anno.srcjar"; fi && rm -rf "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/srcjars" "out/soong/.intermediates/packages/apps/Nfc/NfcNci/android_common/javac/classes"
@Override
@Override
@Override
@Override
packages/apps/Nfc/src/com/android/nfc/cardemulation/CardEmulationManager.java:584: error: CardEmulationManager.CardEmulationInterface is not abstract and does not override abstract method isEuiccSupported() in INfcCardEmulation
packages/apps/Nfc/src/com/android/nfc/cardemulation/CardEmulationManager.java:883: error: recoverRoutingTable(int) in CardEmulationManager.CardEmulationInterface cannot implement recoverRoutingTable(int) in INfcCardEmulation
@Override
@Override
9 errors
06:13:52 ninja failed with: exit status 1
#### failed to build some targets (02:55:54 (hh:mm:ss)) ####
oranges@apple:~/work/Android15/gulukai/android15$
4,261件の閲覧回数
jimmychan
AE is trying to build the BSP try to reproduce the issue. Will let you know when I get any update.
4,165件の閲覧回数
robertosartori
Hi Jimmy, any update?
4,141件の閲覧回数
robertosartori
4,089件の閲覧回数
jimmychan
The NXP official patch is for Android 15 r1 AOSP.  As there are many changes in the newer release compare with the r1, you may need to change it one by one.
For example, for this error,
Put the following function in final class NfcAdapterService extends INfcAdapter.Stub.
@Override
public Map<String, Integer> fetchActiveNfceeList() throws RemoteException {
       Map<String, Integer> map = new HashMap<String, Integer>();
        if (isNfcEnabled()) {
                    map = mDeviceHost.dofetchActiveNfceeList();
        return map;
FYI. You may copy it from NfcService.java - Android Code Search.
You could compare the code different between the AOSP release so you could change the code accordingly.
Another error:
@Override
For this error, the function at NfcService.java:2164 is not match in frameworks/base/nfc/java/android/nfc/INfcAdapter.aidl.
You could find the same function in the newer release (for example: r30) and then replace the mismatch one in NfcService.java.
4,455件の閲覧回数
jimmychan
I will check this with the internal AE. I will let you know when I get any update.
4,371件の閲覧回数
robertosartori
Hi @jimmychan , any news? Thanks!
4,361件の閲覧回数
jimmychan
Sorry for the long waiting. I am still waiting for the AE reply. I will let you know ASAP when I get the update.
%3CLINGO-SUB%20id%3D%22lingo-sub-2183182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAndroid%2015%20NXP%20BSP%201.2.0%E3%81%A8NFC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3EAndroid%20%E3%81%A7%3CSPAN%3EPN7160%3C%2FSPAN%3E%20NFC%20%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%92%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14608.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14608.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81Android%2015%20r14%E3%82%BF%E3%82%B0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%9FiMX8MP%E3%81%A7Android%2015%201.2.0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81Android%2015%20r1%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%B8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%812%20%E3%81%A4%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AE%E9%96%93%E3%81%AB%20NFC%20Android%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AB%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E5%8A%A0%E3%81%88%E3%82%89%E3%82%8C%E3%80%812%20%E3%81%A4%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%AA%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Epackages%2Fapps%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2FNfcService.java%3A1762%3A%20error%3A%20NfcService.NfcAdapterService%20is%20not%20abstract%20and%20does%20not%20override%20abstract%20method%20fetchActiveNfceeList()%20in%20INfcAdapter%0A%20%20%20%20final%20class%20NfcAdapterService%20extends%20INfcAdapter.Stub%20%7B%0A%20%20%20%20%20%20%20%20%20%20%5E%0Apackages%2Fapps%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2FNfcService.java%3A2164%3A%20error%3A%20method%20does%20not%20override%20or%20implement%20a%20method%20from%20a%20supertype%0A%20%20%20%20%20%20%20%20%40Override%0A%20%20%20%20%20%20%20%20%5E%0Apackages%2Fapps%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2FNfcService.java%3A2260%3A%20error%3A%20method%20does%20not%20override%20or%20implement%20a%20method%20from%20a%20supertype%0A%20%20%20%20%20%20%20%20%40Override%0A%20%20%20%20%20%20%20%20%5E%0Apackages%2Fapps%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2FNfcService.java%3A2544%3A%20error%3A%20method%20does%20not%20override%20or%20implement%20a%20method%20from%20a%20supertype%0A%20%20%20%20%20%20%20%20%40Override%0A%20%20%20%20%20%20%20%20%5E%0Apackages%2Fapps%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2FNfcService.java%3A2608%3A%20error%3A%20method%20does%20not%20override%20or%20implement%20a%20method%20from%20a%20supertype%0A%20%20%20%20%20%20%20%20%40Override%0A%20%20%20%20%20%20%20%20%5E%0Apackages%2Fapps%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2Fcardemulation%2FCardEmulationManager.java%3A584%3A%20error%3A%20CardEmulationManager.CardEmulationInterface%20is%20not%20abstract%20and%20does%20not%20override%20abstract%20method%20isEuiccSupported()%20in%20INfcC%0A%20%20%20%20final%20class%20CardEmulationInterface%20extends%20INfcCardEmulation.Stub%20%7B%0A%20%20%20%20%20%20%20%20%20%20%5E%0Apackages%2Fapps%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2Fcardemulation%2FCardEmulationManager.java%3A883%3A%20error%3A%20recoverRoutingTable(int)%20in%20CardEmulationManager.CardEmulationInterface%20cannot%20implement%20recoverRoutingTable(int)%20in%20INfcCard%0A%20%20%20%20%20%20%20%20public%20boolean%20recoverRoutingTable(int%20userHandle)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5E%0A%20%20return%20type%20boolean%20is%20not%20compatible%20with%20void%0Apackages%2Fapps%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2Fcardemulation%2FCardEmulationManager.java%3A855%3A%20error%3A%20method%20does%20not%20override%20or%20implement%20a%20method%20from%20a%20supertype%0A%20%20%20%20%20%20%20%20%40Override%0A%20%20%20%20%20%20%20%20%5E%0Apackages%2Fapps%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2Fcardemulation%2FCardEmulationManager.java%3A882%3A%20error%3A%20method%20does%20not%20override%20or%20implement%20a%20method%20from%20a%20supertype%0A%20%20%20%20%20%20%20%20%40Override%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81Android%2015%20r1%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%20API%20%E3%82%92%E5%B0%8E%E5%85%A5%E3%81%99%E3%82%8B%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fandroid.googlesource.com%2Fplatform%2Fframeworks%2Fbase%2F%2B%2F9fa0481604f727087a7d752c32ff7789372fbb88%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fandroid.googlesource.com%2Fplatform%2Fframeworks%2Fbase%2F%2B%2F9fa0481604f727087a7d752c32ff7789372fbb88%3C%2FA%3E%3C%2FP%3E%3CP%3ENXP%20%E3%81%AE%E6%9C%80%E6%96%B0%E3%81%AE%20BSP%20%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%20NXP%20NFC%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E%E3%83%AD%E3%83%99%E3%83%AB%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202267%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20Android%2015%20NXP%20BSP%201.2.0%20and%20%20NFC%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202267%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%20%E5%85%AC%E5%BC%8F%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%20Android%2015%20r1%20AOSP%20%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%20r1%20%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E5%A4%9A%E3%81%8F%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E5%8A%A0%E3%81%88%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%811%20%E3%81%A4%E3%81%9A%E3%81%A4%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2FNfcService.java%3A1762%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20NfcService.NfcAdapterService%20%E3%81%AF%E6%8A%BD%E8%B1%A1%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81INfcAdapter%20%E3%81%AE%E6%8A%BD%E8%B1%A1%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%20fetchActiveNfceeList()%20%E3%82%92%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E6%9C%80%E7%B5%82%E3%82%AF%E3%83%A9%E3%82%B9%20NfcAdapterService%20%E3%81%AF%20INfcAdapter.Stub%20%E3%82%92%E6%8B%A1%E5%BC%B5%E3%81%97%E3%81%BE%E3%81%99%20%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AC%A1%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E3%80%81NfcAdapterService%20%E3%81%8C%20INfcAdapter.Stub%20%E3%82%92%E6%8B%A1%E5%BC%B5%E3%81%99%E3%82%8B%E6%9C%80%E7%B5%82%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E6%9C%80%E7%B5%82%E3%82%AF%E3%83%A9%E3%82%B9%20NfcAdapterService%20%E3%81%AF%20INfcAdapter.Stub%20%E3%82%92%E6%8B%A1%E5%BC%B5%E3%81%97%E3%81%BE%E3%81%99%20%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%40%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%3CBR%20%2F%3E%E3%83%91%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%20Map%3CSTRING%3E%20fetchActiveNfceeList()%20%E3%81%AF%20RemoteException%20%E3%82%92%E3%82%B9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%20%7B%3CBR%20%2F%3E%20Map%20map%20%3D%20%E6%96%B0%E3%81%97%E3%81%84%20HashMap()%3B%3CBR%20%2F%3E%20if%20(isNfcEnabled())%20%7B%3CBR%20%2F%3E%E3%83%9E%E3%83%83%E3%83%97%20%3D%20mDeviceHost.dofetchActiveNfceeList()%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%7D%3C%2FSTRING%3E%3C%2FP%3E%0A%3CP%3E..%3C%2FP%3E%0A%3CP%3E..%3C%2FP%3E%0A%3CP%3E%E3%81%94%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcs.android.com%2Fandroid%2Fplatform%2Fsuperproject%2F%2B%2Fandroid-15.0.0_r30%3Apackages%2Fapps%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2FNfcService.java%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENfcService.java%20-%20Android%20%E3%82%B3%E3%83%BC%E3%83%89%E6%A4%9C%E7%B4%A2%E3%81%8B%E3%82%89%E3%82%B3%E3%83%94%E3%83%BC%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EAOSP%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E9%96%93%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%88%A5%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2Fsrc%2Fcom%2FAndroid%2Fnfc%2FNfcService.java%3A2164%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E6%96%B9%E6%B3%95%E3%81%AF%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%40%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81%20%3CSPAN%3ENfcService.java%3A2164%20%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%8C%20frameworks%2Fbase%2Fnfc%2Fjava%2Fandroid%2Fnfc%2FINfcAdapter.aidl%20%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(%E4%BE%8B%3A%20r30)%20%E3%81%A7%E5%90%8C%E3%81%98%E9%96%A2%E6%95%B0%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%A6%E3%80%81%20%3CSPAN%3ENfcService.java%20%E5%86%85%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Android%2015%20NXP%20BSP%201.2.0%20and%20%20NFC%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F1422%22%20target%3D%22_blank%22%3E%40jimmychan%3C%2FA%3E%E3%81%93%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%9B%B4%E6%96%B0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20Android%2015%20NXP%20BSP%201.2.0%20and%20%20NFC%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%9F%E3%83%BC%E3%80%82%E4%BD%95%E3%81%8B%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20Android%2015%20NXP%20BSP%201.2.0%20and%20%20NFC%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAE%20%E3%81%AF%20BSP%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E6%9B%B4%E6%96%B0%E3%81%8C%E3%81%82%E3%81%A3%E3%81%9F%E3%82%89%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20Android%2015%20NXP%20BSP%201.2.0%20and%20%20NFC%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F1057%22%20target%3D%22_blank%22%3E%40%E3%82%B8%E3%83%9F%E3%83%BC%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AECASE%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%80%82%E7%A7%81%E3%81%AE%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE1%E4%BA%BA%E3%81%8C%E3%80%81PN7160%E3%82%92Android%20OS%2015%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FLauncher3%2Fsrc%2Fcom%2FAndroid%2Flauncher3%2Fresponsive%2FHotseatSpecsProvider.kt%3A54%3A9%3A%20%E8%AD%A6%E5%91%8A%3A%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%20'dimensionType'%20%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%83%A1%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%97%3A%20%E3%83%87%E3%82%A3%E3%83%A1%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%97%E3%80%81%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2F%E3%82%A2%E3%83%97%E3%83%AA%2FLauncher3%2Fsrc%2Fcom%2FAndroid%2Flauncher3%2Futil%2FLauncherLayoutBuilder.kt%3A170%3A13%3A%E8%AD%A6%E5%91%8A%3A%20%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%20'ItemTarget'%20%E5%86%85%E3%81%AE%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AF%20'children'%20%E3%81%A7%E3%81%99%E3%80%82%E5%90%8D%E5%89%8D%E4%BB%98%E3%81%8D%E5%BC%95%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%A8%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EchildrenIgnored%3A%20List%3CNODE%3E%3F%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20%5B%2042%25%2055590%2F131966%5D%20%2F%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%3ANfcNci%20javac%20%5B%E5%85%B1%E9%80%9A%5D%20(%E5%84%AA%E5%85%88%E5%BA%A6%3A%2022)%3CBR%20%2F%3E%E5%A4%B1%E6%95%97%3A%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2FNfcNci.jar%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno.srcjar%3CBR%20%2F%3Erm%20-RF%20%22out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fclasses%22%E3%80%8Cout%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno%E3%80%8D%22out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno.srcjar.tmp%22%E3%80%8Cout%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fsrcjars%E3%80%8D%E3%80%8Cout%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2FNfcNci.jar.tmp%E3%80%8D%26amp%3B%26amp%3B%20mkdir%20-p%20%22out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fclasses%22%E3%80%8Cout%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno%E3%80%8D%E3%80%8Cout%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fsrcjars%E3%80%8D%26amp%3B%26amp%3B%20out%2Fhost%2FLinux-x86%2Fbin%2Fzipsync%20-d%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fsrcjars-l%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fsrcjars%2Flist-f%20%22*.java%22out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2Fapp%2Fpendingintent.srcjar%20out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2Fcontent%2Fcomponent_name.srcjar%20out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2Fcontent%2Fintent.srcjar%20out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2Fnfc%2Faid_group.srcjar%20out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2Fnfc%2Fapdu_service_info.srcjar%20out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2Fnfc%2Fcard_emulation.srcjar%20out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2Fnfc%2Fndef.srcjar%20out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2Fnfc%2Fnfc_fservice_info.srcjar%20out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2Fnfc%2Fnfc_service.srcjar%20out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2Fos%2Fpatternmatcher.srcjar%20out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2Fos%2Fpersistablebundle.srcjar%20out%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework-nfc-javastream-protos%2Fgen%2Fgensrcs%2Fframeworks%2Fbase%2Fcore%2Fproto%2FAndroid%2F%E3%83%97%E3%83%A9%E3%82%A4%E3%83%90%E3%82%B7%E3%83%BC.srcjar%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fgen%2FAndroid%2FR.srcjar%26amp%3B%26amp%3B%20(if%20%5B%20-s%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fsrcjars%2Flist%5D%20%7C%7C%20%5B%20-s%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2FNfcNci.jar.rsp%20%5D%20%3B%20%E6%AC%A1%E3%81%AB%E3%80%81out%2Fhost%2FLinux-x86%2Fbin%2Fsoong_javac_wrapper%20prebuilts%2Fjdk%2Fjdk21%2FLinux-x86%2Fbin%2Fjavac%20-J-Xmx4096M%20-J-XX%3AOnError%3D%22cat%20hs_err_pid%25p.log%22-J-XX%3ACICompilerCount%3D6%20-J-XX%3A%2BUseDynamicNumberOfGCThreads%20-J-XX%3A%2BTieredCompilation%20-J-XX%3ATieredStopAtLevel%3D1%20-Xmaxerrs%209999999%20-encoding%20UTF-8%20-sourcepath%20%22%22%20-g%20-XDskipDuplicateBridges%3Dtrue%20-XDstringConcat%3Dinline%20-proc%3Anone%20-Xlint%3A-dep-ann%20--system%3Dout%2Fsoong%2F.intermediates%2Fbuild%2Fsoong%2Fjava%2Fcore-libraries%2Fstable-core-platform-api-stubs-system-modules%2Fandroid_common%2Fsystem%20-classpath%20out%2Fsoong%2F.intermediates%2Fvendor%2Fnxp%2Fframeworks%2Fnfc%2Fcom.nxp.nfc%2Fandroid_common%2Fturbine-combined%2Fcom.nxp.nfc.jar%3Aout%2Fsoong%2F.intermediates%2Fvendor%2Fnxp%2Fframeworks%2Fnfc%2Fcom.nxp.nfc%2Fandroid_common%2Frepackaged-jarjar%2Fturbine%2Fcom.nxp.nfc.jar%3Aout%2Fsoong%2F.intermediates%2Fvendor%2Fnxp%2Fframeworks%2Femvco%2Fcom.nxp.emvco%2Fand%20roid_common%2Fturbine-combined%2Fcom.nxp.emvco.jar%3Aout%2Fsoong%2F.intermediates%2Fvendor%2Fnxp%2Fframeworks%2Femvco%2Fcom.nxp.emvco%2Fandroid_common%2Frepackaged-jarjar%2Fturbine%2Fcom.nxp.emvco.jar%3Aout%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fnfc%2Fframework-nfc.impl%2Fandroid_common%2Fjarjar%2Fturbine%2Fframework-nfc.jar%3Aout%2Fsoong%2F.inter%20mediates%2Fframeworks%2Fbase%2Fframework%2Fandroid_common%2Fturbine-combined%2Fframework.jar%3Aout%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fframework%2Fandroid_common%2Frepackaged-jarjar%2Fturbine%2Fframework.jar%3Aout%2Fsoong%2F.intermediates%2Fframeworks%2Fbase%2Fomapi%2Faidl%2Fandroid.se.omapi-V1-java%2Fandroid_common%2Fturbine-combined%2Fandro%20id.se.omapi-V1-java.jar%3Aout%2Fsoong%2F.intermediates%2Fprebuilts%2Fsdk%2Fcurrent%2Fandroidx%2Fm2repository%2Fandroidx%2Fannotation%2Fannotation-jvm%2F1.9.0-rc01%2Fandroidx.annotation_annotation%2Fandroid_common%2Fcombined%2Fandroidx.annotation_annotation.jar%3Aout%2Fsoong%2F.intermediates%2Fprebuilts%2Fsdk%2Fcurrent%2Fandroidx%2Fm2repository%2Fandr%20oidx%2Fappcompat%2Fappcompat%2F1.8.0-alpha01%2Fandroidx.appcompat_appcompat%2Fandroid_common%2Fturbine-combined%2Fandroidx.appcompat_appcompat.jar%3Aout%2Fsoong%2F.intermediates%2Fpackages%2Fapps%2FNfc%2Fbluetooth-protos-nfc-enums-java-gen%2Fandroid_common%2Fturbine-combined%2Fbluetooth-protos-nfc-enums-java-gen.jar%3Aout%2Fsoong%2F.interm%20ediates%2Fprebuilts%2Fsdk%2Fcurrent%2Fextras%2Fmaterial-design-x%2Fcom.google.android.material_material%2Fandroid_common%2Fturbine-combined%2Fcom.google.android.material_material.jar%3Aout%2Fsoong%2F.intermediates%2Fframeworks%2Flibs%2Fmodules-utils%2Fjava%2Fcom%2Fandroid%2Finternal%2Futil%2Fmodules-utils-fastxmlserializer%2Fandroid_common%2Fturbine-combined%2Fmodules-utils-fastxmlserializer.jar%3Aout%2Fsoong%2F.intermediates%2Fframeworks%2Flibs%2Fmodules-utils%2Fjava%2Fcom%2Fandroid%2Fmodules%2Futils%2Fmodules-utils-shell-command-handler%2Fandroid_common%2Fturbine-combined%2Fmodules-utils-shell-command-handler.jar%3Aout%2Fsoong%2F.intermediates%2Fsystem%2Flibsysprop%2Fsrcs%2FPlatformP%20roperties%2Fandroid_common%2Fturbine-combined%2FPlatformProperties.jar%3Aout%2Fsoong%2F.intermediates%2Fpackages%2Fapps%2FNfc%2Fproto%2Fnfc-event-log-proto%2Fandroid_common%2Fturbine-combined%2Fnfc-event-log-proto.jar%3Aout%2Fsoong%2F.intermediates%2Fpackages%2Fapps%2FNfc%2Fflags%2Fnfc_flags_lib%2Fandroid_common%2Fturbine-combined%2Fnfc_flags_lib.jar%20-source%2017%20-target%2017%20-d%20out%2Fsoong%2F.intermediates%2Fpackages%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fclasses-s%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno%40out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2FNfcNci.jar.rsp%20%40out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fsrcjars%2Flist%3B%20fi%20)%20%26amp%3B%26amp%3B%20out%2Fhost%2FLinux-x86%2Fbin%2Fsoong_zip%20-jar%20-o%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno.srcjar.tmp%20-C%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno-D%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno%26amp%3B%26amp%3B%20out%2Fhost%2FLinux-x86%2Fbin%2Fsoong_zip%20-jar%20-o%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2FNfcNci.jar.tmp%20-C%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fclasses-D%20out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fclasses%26amp%3B%26amp%3B%20if%20!%20cmp%20-s%20%22out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2FNfcNci.jar.tmp%22%E3%80%8Cout%2Fsoong%2F.intermediates%2Fpackages%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2FNfcNci.jar%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%80%81mv%E3%80%8Cout%2Fsoong%2F.intermediates%2Fpackages%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2FNfcNci.jar.tmp%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8Cout%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2FNfcNci.jar%E3%80%8D%3Bfi%20%26amp%3B%26amp%3B%20if%20!%20cmp%20-s%20%22out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno.srcjar.tmp%22%E3%80%8Cout%2Fsoong%2F.intermediates%2Fpackages%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno.srcjar%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%80%81mv%E3%80%8Cout%2Fsoong%2F.intermediates%2Fpackages%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno.srcjar.tmp%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8Cout%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fanno.srcjar%E3%80%8D%3Bfi%20%26amp%3B%26amp%3B%20rm%20-RF%20%22out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fsrcjars%22%22out%2Fsoong%2F.intermediates%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2Fapps%2FNfc%2FNfcNci%2Fandroid_common%2Fjavac%2Fclasses%22%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2F%E3%82%A2%E3%83%97%E3%83%AA%2FNfc%2Fsrc%2Fcom%2Fandroid%2Fnfc%2FNfcService.java%3A1762%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20NfcService.NfcAdapterService%20%E3%81%AF%E6%8A%BD%E8%B1%A1%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81INfcAdapter%20%E3%81%AE%E6%8A%BD%E8%B1%A1%E6%96%B9%E6%B3%95%20fetchActiveNfceeList()%20%E3%82%92%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E6%9C%80%E7%B5%82%E3%82%AF%E3%83%A9%E3%82%B9%20NfcAdapterService%20%E3%81%AF%20INfcAdapter.Stub%20%E3%82%92%E6%8B%A1%E5%BC%B5%E3%81%97%E3%81%BE%E3%81%99%20%7B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2F%E3%82%A2%E3%83%97%E3%83%AA%2FNfc%2Fsrc%2Fcom%2FAndroid%2Fnfc%2FNfcService.java%3A2164%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E6%96%B9%E6%B3%95%E3%81%AF%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%40%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%3CBR%20%2F%3E%5E%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2F%E3%82%A2%E3%83%97%E3%83%AA%2FNfc%2Fsrc%2Fcom%2FAndroid%2Fnfc%2FNfcService.java%3A2260%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%81%AF%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%40%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%3CBR%20%2F%3E%5E%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2F%E3%82%A2%E3%83%97%E3%83%AA%2FNfc%2Fsrc%2Fcom%2FAndroid%2Fnfc%2FNfcService.java%3A2544%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E6%96%B9%E6%B3%95%E3%81%AF%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%40%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%3CBR%20%2F%3E%5E%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2F%E3%82%A2%E3%83%97%E3%83%AA%2FNfc%2Fsrc%2Fcom%2FAndroid%2Fnfc%2FNfcService.java%3A2608%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E6%96%B9%E6%B3%95%E3%81%AF%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%40%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%3CBR%20%2F%3E%5E%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2F%E3%82%A2%E3%83%97%E3%83%AA%2FNfc%2Fsrc%2Fcom%2FAndroid%2Fnfc%2Fcardemulation%2FCardEmulationManager.java%3A584%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20CardEmulationManager.CardEmulationInterface%20%E3%81%AF%E6%8A%BD%E8%B1%A1%E7%9A%84%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81INfcCardEmulation%20%E3%81%AE%E6%8A%BD%E8%B1%A1%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%20isEuiccSupported()%20%E3%82%92%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E6%9C%80%E7%B5%82%E3%82%AF%E3%83%A9%E3%82%B9%20CardEmulationInterface%20%E3%81%AF%20INfcCardEmulation.Stub%20%E3%82%92%E6%8B%A1%E5%BC%B5%E3%81%97%E3%81%BE%E3%81%99%20%7B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2F%E3%82%A2%E3%83%97%E3%83%AA%2FNfc%2Fsrc%2Fcom%2FAndroid%2Fnfc%2Fcardemulation%2FCardEmulationManager.java%3A883%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20CardEmulationManager.CardEmulationInterface%20%E3%81%AE%20recoverRoutingTable(int)%20%E3%81%AF%20INfcCardEmulation%20%E3%81%AE%20recoverRoutingTable(int)%20%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%91%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%E3%83%96%E3%83%BC%E3%83%AB%E5%80%A4recoverRoutingTable(int%20userHandle)%20%7B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%E6%88%BB%E3%82%8A%E5%80%A4%E3%81%AE%E5%9E%8Bboolean%E3%81%AFvoid%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2F%E3%82%A2%E3%83%97%E3%83%AA%2FNfc%2Fsrc%2Fcom%2FAndroid%2Fnfc%2Fcardemulation%2FCardEmulationManager.java%3A855%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E6%96%B9%E6%B3%95%E3%81%AF%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%40%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%3CBR%20%2F%3E%5E%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2F%E3%82%A2%E3%83%97%E3%83%AA%2FNfc%2Fsrc%2Fcom%2FAndroid%2Fnfc%2Fcardemulation%2FCardEmulationManager.java%3A882%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E6%96%B9%E6%B3%95%E3%81%AF%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%40%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%3CBR%20%2F%3E%5E%3CBR%20%2F%3E%209%E4%BB%B6%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E06%3A13%3A52%20ninja%20%E3%81%AF%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FNODE%3E%3C%2FP%3E%3CP%3E%23%23%20%23%23%20failed%20to%20build%20some%20targets%20(02%3A55%3A54%20(hh%3Amm%3Ass))%20%23%23%20%23%23%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%AC%E3%83%B3%E3%82%B8%40apple%3A~%2Fwork%2FAndroid15%2Fgulukai%2Fandroid15%24%3CBR%20%2F%3E%E3%82%AA%E3%83%AC%E3%83%B3%E3%82%B8%40apple%3A~%2Fwork%2FAndroid15%2Fgulukai%2Fandroid15%24%3CBR%20%2F%3E%E3%82%AA%E3%83%AC%E3%83%B3%E3%82%B8%40apple%3A~%2Fwork%2FAndroid15%2Fgulukai%2Fandroid15%24%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Android%2015%20NXP%20BSP%201.2.0%20and%20%20NFC%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%A4%89%E3%81%8A%E5%BE%85%E3%81%9F%E3%81%9B%E3%81%97%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%A0AE%E3%81%AE%E8%BF%94%E4%BA%8B%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9B%B4%E6%96%B0%E3%81%8C%E5%B1%8A%E3%81%8D%E6%AC%A1%E7%AC%AC%E3%80%81%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Android%2015%20NXP%20BSP%201.2.0%20and%20%20NFC%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F1422%22%20target%3D%22_blank%22%3E%40jimmychan%3C%2FA%3E%20%E3%80%81%E4%BD%95%E3%81%8B%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185520%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Android%2015%20NXP%20BSP%201.2.0%20and%20%20NFC%20support%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185520%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E7%A4%BE%E5%86%85%E3%81%AEAE%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E6%9B%B4%E6%96%B0%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
