About G2IM+ Digital Switch
加鹏孙
Im testing the chip G2im+,i want use the Digital Switch to drive a LED. But when i write 0020 to the ConfigWord,the LED only flash a short time,it  seem to always in  Data Transfer  mode。 what can i do to keep the out pin at a hight level? thanks.
加鹏孙
李工您好,问题已解决。问题的原因是原来的天线设计有问题,更改天线后就好了。
Kan_Li
Hi Sun,
Did you connect VDD pin to some power supply ? It is required for your scenario.
Kan
加鹏孙
