AN11597,PCBboard firmware code
4,109 次查看
annachen
I am testing the AN11597 ,and the board and the NTAG I2C DEMO works good,and i make my own pcbboard,in order to make it works,can you please provide the pcbboard firmware version of 1.6,please?
4 回复数
3,803 次查看
annachen
And in what Build Environment is it worked,please
3,803 次查看
Jorge_Gonzalez
Hello anna chen:
- If you have the NTAG I2C Demoboard (without LCD display) the firmware sources are in the next product page under Software & Tools:
NTAG I²C - Energy harvesting NFC Forum T|NXP
- In case you used the NTAG I2C plus explorer board (with onboard LCD display) the firmware is in the next page under Downloads:
NTAG I²C plus Explorer Kit|NXP
In either case the projects were developed with LPCXpresso IDE.
I hope this helps.
Regards!
Jorge Gonzalez
3,803 次查看
annachen
Dear Jorge Gonzalez:
I downloaded from the https://www.lpcware.com the latest version of v8.1.4,unfortunately it can't setup on my computer(windows xp),which version can work on the xp systems please?
3,803 次查看
Jorge_Gonzalez
Hi anna chen:
Windows XP is no longer supported, but according to the next post in lpcware forum the last version of LPCXpresso IDE tested with Windows XP was 7.0.2:
Windows XP | www.LPCware.com
You can try that one. There is a list of downloads for Windows in the next link:
LPCXpresso IDE Windows Installer | www.LPCware.com
:smileyinfo: NOTE: I cannot guarantee that the NTAG I2C projects mentioned will work with that version of the IDE.
Regards!
Jorge Gonzalez
