I have successfully mounted the A1006 to the i2c circuit, how can I detect if the circuit is working or not. I can use i2cdetect and i2cdump commands in linux system, but the detected registers are all 01, not quite sure, whether it is working or not.
I need support for this ic, can you share?
It is not the right way with A1006, please kindly refer to Get Started with the KIT-A1006-Shield | NXP for details.
Hope that helps,
Kan
