930105_en-US
930105_en-US
930105_en-US
How select "Language standard"
if I create a new SDK project (from the SDK project wizard), after selecting board and other configuration (device packages, project type, components...), I get "Advanced project settings" screen where I can select the MCU C Compiler. By default, "Language standard" points to "Compiler default", but I can choose if I want "GNU C90 (-std=gnu90).
However, if I create a new C project (not SDK), I can't see this screen and I can't choose "Language standard".
How can I change that?
Thanks.
Re: How select "Language standard"
Great breakdown on choosing the right language standard—your explanation really clears up a lot of confusion I’ve seen around this topic. While experimenting with different settings, I stumbled on some Elvish translation tips that made testing character sets a bit more fun. It’s interesting how adjusting standards can change the behavior of compilers in subtle ways. Looking forward to more posts like this!
Hi ptcaos,
If you right click in your project click in properties->C/C++ Build->Settings->MCU C Compiler->Dialect you can select the language:
Alexis Andalon
No ratings
Version history
Last update:
‎12-12-2025 04:54 AM
Updated by:
