890866_en-US
890866_en-US
890866_en-US
FXTH87xx11 Pressure out of range
Hello everyone!
      I encountered a strange problem when I measured the pressure under normal pressure. It works fine when debugging the sensor. After the sensor is powered down and restarted, the measurement pressure prompt is out of range. I want to know how to get back to normal after a power outage, or what details I need to pay attention to (I have tried other programs to make sure the chip is working properly.)
      Maybe I didn't describe it clearly. I just don't know why the reading pressure value will be out of range. Is it related to stop mode or other configuration?
Thanks in advance!
Pressure SensorsRe: FXTH87xx11 Pressure out of range
Imitate the routine, use the following code before reading the pressure, the situation has improved.
TPMS_LF_ENABLE(CLEAR);
TPMS_INTERRUPT_FLAG=CLEAR;
TPMS_READ_VOLTAGE(TempArr);
补充记录
后面发现通信协议中,有个状态字节包含高压的标记,当该位置1时,气压会显示在高压范围
Re: FXTH87xx11 Power off
标记 (1)
无评分
版本历史
最后更新:
‎02-04-2026 09:13 AM
更新人:
