807651_en-US
807651_en-US
807651_en-US
MPX4115AP port
The data sheet for MPX4115 series lists MPX4115AP as a "ported element". Can someone help me understand what this means and what exactly is the port used for.
Re: MPX4115AP port
Thank you so much!
Re: MPX4115AP port
Hi Megha,
The letter ”A” in the part number means “absolute” so the pressure applied to P1 is measured against the vacuum reference sealed on the P2 side:
Our differential pressure sensors can be identified by a letter “D” in the part number (e.g. MPX5100DP) and two input ports:
Please take a closer look at this article to get a better idea about pressure measurement and level of integration of NXP pressure sensors.
Tomas
Re: MPX4115AP port
Hi Tomas,
     Thank you so much for the reply. Just one more clarification. Does interfacing with a hose/tube connection mean that the sensor can be used as a differential sensor?
Re: MPX4115AP port
Hi Megha,
Ported versions (with AP, AS or ASX suffix) allow pressure to be interfaced to a device via a hose/tube connection.
Tomas
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎02-04-2026 11:04 AM
更新者:
